[Z06] Braking
Old May 18, 2005 | 04:03 PM
Z06tr's Avatar
Z06tr
6th Gear
Default Braking
Hello, I'm new to the forum (Black03Z). I have a question about some of the claims made by aftermarket brake vendors. This one advertises that their rotors will improve 60-0 stopping distances from 125 to 90 ft. My question is that if the tire is at the critical friction point trying to stop the car that has ABS, how will a different rotor stop me any faster?
Old May 18, 2005 | 04:52 PM
robvuk's Avatar
robvuk
I think it's called "marketing".
Old May 18, 2005 | 05:01 PM
User 81424's Avatar
User 81424
It can't, and Welcome!
Old May 18, 2005 | 05:04 PM
Mikey Z's Avatar
Mikey Z
I'm not 100% sure but I think the stopping distance 60 to 0 is much less than 125 ft
Old May 18, 2005 | 08:24 PM
Z06tr's Avatar
Z06tr
6th Gear
Thanks for having me. The add said 125 ft. I don't know where they got that from.
This is the link for the add.
http://www.accuratetechnologies.com/...rcategoryid=18
Old May 19, 2005 | 09:01 AM
User 81424's Avatar
User 81424
BRAKING
E-Town's 1/4-mile strip was also our brake-testing venue, although the 100-0 and 60-0 testing was cut short due to radar equipment malfunctions. But let it be known that with Baur behind the wheel, the best 100-0 stop came in at 317 feet. The Z06 also recorded multiple 117-foot 60-0 readings. Brake fade came into play only slightly, and Steve touted the 12.6-inch front/11.8-inch rear brakes and the quick-cycling ABS system for sucking the 'Vette to the pavement while providing drama-free panic stops. It doesn't get more effortless than this.
http://www.gmhightechperformance.com...es/0410htp_zo/
Old May 19, 2005 | 09:04 AM
User 81424's Avatar
User 81424
Well, TI rotors may have more of an effect on braking than an after market iron rotor. They reduce the rotational mass so much that the tires can work better. I don't know if they can make a 117' to 90' difference but I think they would make a noticeable difference. For:Item: C-5 Corvette Titanium Rotors
Item #: 373-0013
Price: $1,195.00
They better do something!!!!!!!
I'm going to post this thread in Racing and see what the experts say.
Old May 19, 2005 | 11:02 AM
AU N EGL's Avatar
AU N EGL
Item #: 373-0013
Price: $1,195.00
We had several discsions with the developer of the Ti rotors. He finally came out and said that Ti rotor were NOT for 3000+ lbs cars but more for 1800 lbs cars.
There have been a few totally anonoumous tests of these rotors as well. Stopping was ok not great at first, but as the stops became for frequent as in racing they faded real fast. Part of the braking process is friction - or converting Kinetic energy( energy in mortion ) to Static energy ( energy at rest )with a by product of heat. Ti is not a good heat absorption material so he heat had to go someplace. Well the pads glazed over and brake fade was persistant.
In short for that kind of money better to get big Brake Kit from StopTech, Wilwood, Alcon or Brembo.
Old May 19, 2005 | 01:10 PM
User 81424's Avatar
User 81424
Yes, but those were the motorcycle style rotors, these are direct OEM replacements. Other than taking care of where the heat goes, I've read good things about these full size rotors.
Old May 19, 2005 | 03:02 PM
95jersey's Avatar
95jersey
If you are going to use them at a track...don't waste your money. If you want them for show...go for it.
Old May 19, 2005 | 05:44 PM
jnjboc's Avatar
jnjboc
FYI,
If memory serves correctly, road and track has the 60-0 stopping distance on the Z06 at 107 ft!!!
It was the record until the Enzo came along....which I think is 105 ft...
Old May 20, 2005 | 08:53 AM
ATI Performance's Avatar
0ATI Performance
Former Vendor
ATI Performance has a vehicle dedicated to brake development. I have data on 60-0 stops with the OEM brakes and I will be evaluating the Red Devil Brake kit early next week. The marketing on our website is direct from the manufacturer. After we have the data I will post on our website.
We have been using Red Devil Brakes on our track car since the start of last season, but we are evaluating other kits, pads, and our own ABS control algorithms. At the moment we only cary parts on our site that we have used in competition and feel comfortable recomending to our local comunity. So the information we have listed is to the best of our knowledge true, if we find the information different than the manufacturer then we will post it. If we find a better product we will support that on our site.
Please feel free to contact me if you have any questions.
Old May 20, 2005 | 10:09 AM
yellow01's Avatar
yellow01
The ultimate limiter in braking distance on a vehicle is the friction of tire to road surface, i.e. impending lockup.
So the question remains - how do you shorten the braking distance on a vehicle under threshold braking?
Now, fully understand the other issues associated with racing, fade, modulation etc. etc. so clearly understand the value of different friction setups, MOTs and the like, and the effect of optimizing bias.
But as far as 60-0 as the mags and testers do, how does this distance shorten? There's only so much friction available between the tire and the road surface.
Also, I'm not talking a hard stab at the brakes to purposefully induce lockup (overcoming static friction through high impulse) I mean approaching the threshold through increased pressures.
Old May 20, 2005 | 11:32 AM
AU N EGL's Avatar
AU N EGL
I guess 60 to 0 does not mean much to me. But 140- to 60 mph slow downs 3 times evey 2 minutes 30 minuets at time. would be more benifical.
so that is 45 stops from 140 down to 60 mph with in 30 minutes.
Good luck with your tests.
Old May 20, 2005 | 02:41 PM
robvuk's Avatar
robvuk
Except it's not IMPENDING lockup, it's INSIPIENT lockup.
If a given brake pad/rotor setup is capable of locking the wheels, the limiting factor is tire size and weight distribution. A tall car with front engine will require the front tires to do 90% of the braking. A low profile car or better yet, one with a rear engine/weight bias, which helps keep some of the stopping duty on the rear will win. As Au_n_egl pointed out, it's the repeatability that counts in a roadrace.
To Braking
