about lowering
Old May 18, 2005 | 06:07 PM
csmith46's Avatar
csmith46
Default about lowering
my vette is stock height and speed bumps in parking lots and angled driveways already have the car scraping. how do you guy who lower your cars manage not to tear up your front air dam piece and rip up the bottom of the car? it just seems like the car could not go lower without such damage? thanks
Old May 18, 2005 | 06:09 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Wondering the same. Had my fbody pretty low and have had to ask passengers to get out so I could get into my driveway. Sure would like to do it, but hate to worry about every bump.
Old May 18, 2005 | 06:13 PM
jrose7004's Avatar
jrose7004
That little front air dam is on a spring and it hasn't caused any problem!
Old May 18, 2005 | 06:15 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
Rocker rails and Frame savers from A&A, just got mine yesterday. A must have for lowered vettes.
https://www.aandacorvette.com/cart/s...sp?MainCatID=5
Old May 18, 2005 | 06:16 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
That little front air dam (actually those little front air dams - there are three of them) are designed to bend, that's why they're mounted on springs and unlike most vette parts, they're pretty cheap to replace.
Old May 18, 2005 | 06:21 PM
squeezer's Avatar
squeezer
I don't let my wife drive it and everything is fine!
Old May 18, 2005 | 07:47 PM
dajael
Guest
Posts: n/a
You are going to ALWAYS scrape the front "flexible" air dams but you would have to totally "SLAM" it to be low enough to scrape the body.
Like "Jackalope" said...they are cheap to replace if you are so inclined. I use the scraping sound of the air dams as my warning device that I'm close enough to a parking bumper or that I need to take the driveway approach slightly slower. I've scraped the pi$$ out of mine since I lowered it on factory bolts but unless you are under my front end with a flashlight, you can't see any marks (they are barely even noticable as it is).
The point is:
Don't be nervous to lower you car...it's completley reversable if you don't like it. I don't think I've ever read that any CF member has reversed it after lowering. It just looks too damn good!!!
Old May 18, 2005 | 07:49 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Slam it. Once you do you'll never look back.
EG
Old May 18, 2005 | 07:51 PM
SMX's Avatar
SMX
EG
I agree.
Old May 18, 2005 | 10:46 PM
mixermike's Avatar
mixermike
i've been driving lowered trucks and cars for years.it's like anything else,you do it long enough you learn all the tricks and you watch the road.my motto is ( lift it or lower it, don't drive it STOCK )
Old May 18, 2005 | 11:05 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Those plastic spoilers under the front of the car are cheap to replace. However, the two metal crash bars and rocker panels under the car are much more costly and time consuming to replace. My car was lowered yesterday to the max of stock bolts. I have the Z51 suspension so the car only dropped about 3/4''. It isnt much but it is noticeable. Also installed were the rocker frame rails and frame savers. These will save your azz if you have a lowered vette. I bought mine from www.aandacorvette.com. Here are some pics:
Old May 19, 2005 | 12:00 AM
csmith46's Avatar
csmith46
thanks guys - i have the frame rail protectors and the frame saver wheels too so I will give it a try and see what happens. i have the magnetic ride control on my 03 so i hope the ride will not be compromised.
Old May 19, 2005 | 12:10 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Some goodf advice above. I'm lowered all the way on stock bolts. I replaced all 3 front pieces in about 15 minutes for about $57.00.
To about lowering
