I just installed Lg long tube with the off road xpipe. i bought the 02sims and after the install it ran fine no codes till about 12 miles later. It started to sputter and doesnt want to run when im just cruisin. It runs pretty good at WOT. I checked the codes and it came up with these three. Im not sure what they are. Can anyone shed some light one the problem? The codes are Po 300h, P1133 HC, and P1153 HC.
Thanks.
Dan
P1133 and P1153 are codes for the front 02 sensors.
P0300 is an engine misfire code.
Since you said they are LG's...I'm going to take a wild guess here that the front 02 sensor wiring got crossed. The left wire harness goes to the left header. The right harness goes to the right header.
Due to the orientation of the 02 sensors on LH headers, many people make the mistake of crossing the harnesses, and doing so will produce exactly the symptoms you describe.
For the P0300....go back and double check all your wires first. Make sure they all snap in. 2 snaps for the coils and one on the plug. If they all do, then take a look at the plugs themselves. Did they remove them when they installed the headers? Was there a chance one of them got dinged or cracked on the install....
For me, I just forgot to seat the 7 cyl plug wire correctly. Hope it works out...
