Paint Pen?
Old May 18, 2005 | 02:31 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Default Paint Pen?
Anybody using/used one of these touch up pens? How do they work. Worth the $17?
http://www.autovisuals.com/
Old May 18, 2005 | 02:54 PM
joeflyer's Avatar
joeflyer
Default Pen
I've got one. The tip is as fat a a fine-point Sharpie, which is too fat for most chips. It puts on less paint than a syringe, though. The paint is thinner, too. To use it, I fill the chip, then wipe the excess off with a paper towel soaked in alcohol. It takes several coats.
Road_runner's Avatar
Road_runner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Haven't tried that brand but here's a good tip.
http://forums.corvetteforum.com/show...up&forum_id=48
Old May 18, 2005 | 03:01 PM
c3andc5's Avatar
c3andc5
The one I got at Advance Auto Parts only cost $5.99 and it's the exact paint code for my Torch Red coupe. Has a brush end and a pen point end. Works great! I also use a red fine point Sharpie for small (non-chip) scratches.
Old May 18, 2005 | 03:56 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have tried them, 3 seperate times on three different cars. The color did not match once. Not once. You could tell the difference right away. They are crappy IMHO, stick with a toothpick and touch up paint from the dealer.
Old May 18, 2005 | 04:00 PM
JoshVette's Avatar
JoshVette
I was just at my chevy dealership and asked them about touch up paint.
It only cost about 6.50 and he said it was like a fingernail brush...
Old May 18, 2005 | 07:22 PM
EdLedbetter's Avatar
EdLedbetter
Go to your local Corvette dealer and buy the touch up paint in the small bottle - - - unscrew the cap and with a pair of pliers, remove the brush and toss it in your garbage can. Go to your local art supply house and buy the finest tip sable brush they have.
Works great for me.
EEL
Old May 18, 2005 | 07:44 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Works great for me.
EEL
If you've never used a really top quality artists brush, you really don't know what you're missing. They are incredible. Just stiff enough to put the paint exactly where you want it.
Old May 18, 2005 | 08:06 PM
c5BlackBeauty
Lifetime Member
Thanks everyone.....off to the stealer for paint and crafts store for the brush I go.....
Old May 19, 2005 | 09:12 AM
Steve-H's Avatar
Steve-H
Default nail
in many cases a nail used to lay a drop of paint in a chip works much smoother than a brush. pick up a drop and let the drop toouch the spot without letting the nail touch.
Old May 19, 2005 | 10:04 AM
i_york's Avatar
i_york
I got one of these exact pens for my Sebring Silver C5 and it was pretty useless... nice idea in theory, but it just doesn't work in practice.
As already mentioned by someone, not enough paint comes out when you press down on the nib and it doesn't take long before it gets clogged-up. Save your money and go with the age-old tried-and-tested approach of a tooth-pick/fine brush and touch-up paint.
I've found you need to practice some restraint when touching-in stone chips (esp. if it's a daily driver) because if you get carried-away and start touching-up every little pinhead-sized chip, you can end-up with a situation where the touched-up chips are more noticeable than if you'd just left it!
Cheers,
Ian.
Old May 19, 2005 | 01:27 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
You can order these through Eastwood and fill with any paint.
I have them and use them all the time.
Old May 19, 2005 | 05:10 PM
Dirty Howie's Avatar
Dirty Howie
To Paint Pen?
