[Z06] Chrome Wheel Maintenance?
Old May 19, 2005 | 08:13 PM
drdcz06's Avatar
drdcz06
Default Chrome Wheel Maintenance?
Can anyone suggest a product for maintaining chrome wheels? I currently use Windex which seem to work well, but, I am not sure if it is the best solution for chrome...
Thanks in advance for your input...
Old May 19, 2005 | 09:56 PM
hocheehoba's Avatar
hocheehoba
Use 0000 Super Fine Wool pads (make sure it has FOUR ZEROS "0000" and ONLY use it on Chrome that is on medal, not plastic). That will clean them right up and shine like you never seen. You can buy a pack at Walmart or such for about $5.00.
Old May 19, 2005 | 10:54 PM
drdcz06's Avatar
drdcz06
Interesting... I knew you could use 0000 Super Fine Wool pads on windows to remove hard water stains, but, never thought of using it on chrome... I will try it...
thanks...
Old May 20, 2005 | 07:59 AM
hocheehoba's Avatar
hocheehoba
Yes, and as you metioned.. windows.
Old May 20, 2005 | 12:57 PM
t56gen3's Avatar
t56gen3
I keep mine Zaino'd to catch less brake dust and make them easier to wash. Also helps with the water-spotting considerably.
Old May 21, 2005 | 07:02 AM
AFVETTE's Avatar
AFVETTE
When I had my repo chrome Z06 wheels I used Mother's Chrome Cleaner and Polish. Then I'd follow that up with a coat of whatever Zaino I was using. After 3 years as a daily driver they looked brand new.
Hope this helps.
Tom
Old May 21, 2005 | 07:14 AM
barondw's Avatar
barondw
There are also special sealers made for the wheel before applying wax. There are many alternates to Zaino that do just as well or better.
To Chrome Wheel Maintenance?
