Bird Dropping Stains
Old May 21, 2005 | 12:22 PM
Vector's Avatar
Vector
Originally Posted by vettenovice
I'd start with the clay bar option first since there's no abrasion and slowly work my way up the abrasion ladder until solved.
Good luck!
Man, those birds can eat some nasty stuff!
Old May 21, 2005 | 02:38 PM
gpotski's Avatar
gpotski
Originally Posted by SGT. PYLE
Use a clay bar, it will come right off! DO NOT use Dawn!!! Dawn is for dishes, not $50K Corvette's. The clay bar will take all wax, deposits, everything off the area used except the clearcoat. Clay it then apply your wax. Easy fix!
I used a claybar on an area of concern (aka bird ****) but it did nothing. I cannot feel any change in smoothness of the area, the paint looks good, but at an angle, the area is visible. I imagine I'll need it wet sanded out someday.
Old May 21, 2005 | 03:38 PM
jmrc5's Avatar
jmrc5
A while back I put a two foot long, 1/8 in wide scratch down to bare metal over the wheel well of my Silverado pickup. Because it was so bad, I felt I didn't have a lot to lose so I bought some Plasti-kote touch up paint, clearcoat, and leveler at Pep Boys. The leveler is amazing! It removes the touch up paint and smoothly levels it to the level of the factory paint. The bottle claims it will not remove the factory paint. I was supposed to apply the clearcoat, then after a short drying time, apply the leveler to the area where I touched up the clearcoat. It looked so good, I didn't bother to touch up the clearcoat. My boss, who had seen the damage, did not believe I didn't take it to a body shop. A year later it, still looks good.
I'm not sure I would mess with the finish on my Vette, but if nothing else works, and the alternative is getting it painted because of bird droppings, I think I would give this stuff a try on the Vette.
Old May 21, 2005 | 07:17 PM
Darion's Avatar
Darion
Originally Posted by EscapePod
I'm just thankful cows don't fly.
Old May 21, 2005 | 09:09 PM
VetteDawg's Avatar
VetteDawg
3M Swirl Mark Remover for Dark Colored Cars
...might take several applications and some grease of the elbow...
You'll probably want to wash the area and Z5 - Z2 after.
- good luck -
Old May 21, 2005 | 09:15 PM
American Dream's Avatar
American Dream
Boy, did I start a s#%t storm when I posted a similar problem last June... Initiated a scientific debate on the pH of bird droppings and other boring stuff. Still have the marks on my mag red clear coat... Don't believe the Dawn and Clay Bar hype. I just didn't have the you-know-whats to apply anything abrasive for fear of making a small problem worse. Lesson learned: if you see droppings, REMOVE THEM ASAP before they etch your clear coat, even if it means buying bottled water and using the t-shirt on your back to wipe it up. Preferably your girlfriends t-shirt, though, and make sure to apply the water before she takes it off! - ad
Old May 21, 2005 | 09:23 PM
VetteDawg's Avatar
VetteDawg
exactly! this is the best advice anyone can give. birds eat nasty stuff and a dropping on your vette must be treated as an emergency.
Old May 23, 2005 | 08:19 PM
Dave Fontanini's Avatar
Dave Fontanini
Default Bird Dropping Stains
Thanks to everyone for your suggestions. I will definitely give some of them a try.
Since I have the Mequirs scratch remover I going to start there. Will let you know how I come out!
Old May 23, 2005 | 09:07 PM
Hoosier Red's Avatar
Hoosier Red
I would be really surprised if the Scratch X doesn't work.....I was pretty concerned about what it would do to the finish and I was surprised that it didn't dull the surrounding area at all. I can't see them at all and I think I have a pretty critical eye.
