How long does it take to settle after lowering?
Old May 21, 2005 | 05:38 PM
ls1vette97's Avatar
ls1vette97
Default How long does it take to settle after lowering?
Today I finally lowered my car front and rear. On the rear i cut the bushings, and the leaf spring does not sit on the "A arm" anymore for some reason even though i've driven it around the block quite a few times. Also on the front, i've turned the bolts as much as possible, but for some reason the right side is about .5" lower then the left. Does the car need time to settle, or did i do something wrong? Thanks, Chris.
Old May 21, 2005 | 05:42 PM
pewterwest99's Avatar
pewterwest99
i've heard that it takes time to settle, give it a week or so and drive it around
Old May 21, 2005 | 05:46 PM
ls1vette97's Avatar
ls1vette97
I'm just worried about the leaf spring being about 1" lower than the A arm, and having no contact with it at all!
Old May 21, 2005 | 06:39 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you are talking about the rear...there should be a gap..a big gap!. The longer the gap, the lower the car will be. The rear is set up the opposite of the front, the spring is under the control arm, and (via the adjusting bolts), is pulling down on the arm, so the looser the adjusting nuts are, or the longer the bolt...the more it will be lowered.
On the front, the spring is above the arm, and pressing down on it, it's not possible to have any gap on the front, other than the thickness of the bushing.
Old May 21, 2005 | 07:05 PM
ls1vette97's Avatar
ls1vette97
Thanks for the great advice! Now i just hope the front settles evenly....
To How long does it take to settle after lowering?
