[Z06] LS7 Coming in August
Is anyone considering swapping to the new gen`s power mill? A close friend of mine has an 02 ZO6 which is why I am interested.
I think the new Z06 looks like sh it and actually like the looks of a regular C6 Coupe over the new Z!!! Man though, i would kill for that drivetrain, performance, technology and GM backed warranty in my EB 02 Zs body!!!!!!!!
P.S. Please send check my way too.
FOR RELEASE: 2005-03-22
CONTACTS
Most Powerful Small-Block Ever - Available in a Crate
DETROIT - Chevrolet unveiled the 2006 Corvette Z06 at Detroit's North American International Auto Show in January, and now GM Performance Parts is unveiling the crate engine version of the LS7 engine that powers it. This latest Z06, billed as "the fastest, most powerful car ever offered by Chevrolet and GM," has enthusiasts looking for that kind of power in a crate engine. GM Performance Parts is ready to end that search as it offers the LS7 (P/N 17802397) at GM dealerships and Authorized Centers, nationwide in August.
This small-block V-8 dreams big, displacing big-block cubic inches at 7.0 Liters (427 cubic inches) and big-block power at 500 hp at 6200 rpm. It also benches 475 lb.-ft. of torque at 4800 rpm. Helping to create its high power and high revving capability are details such as cylinder heads with computer numerical control (CNC) intake and exhaust ports and combustion chambers - which creates ports with surgical accuracy for maximum power production. In addition, the intake valves and connecting rods are made out of high-strength lightweight titanium.
The LS7 engines are assembled by hand at GM Powertrain's new Performance Build Center in Wixom, Mich.
Pricing will be announced mid-summer; however, early estimates indicate that the GMPP LS7 crate engine will sell for well below the cost of comparable custom-built aftermarket engines.
Enthusiasts who must have the latest technology, maximum horsepower and the largest production cubic-inch displacement small-block ever built will be able to purchase the LS7, as well as other GM Performance Parts crate engines, blocks, heads and components, from GM dealerships or GMPP Authorized Centers nationwide. Following the release of the LS7 in a crate, GMPP will offer select parts, such as the crankshaft, connecting rods, cylinder heads and valves separately, and in kit form. To locate the closest GM dealership or GMPP Authorized Center or dealership, call 1-800-GM USE US or visit www.goodwrench.com.
General Motors (NYSE: GM), the world's largest vehicle manufacturer, designs, builds, and markets cars and trucks worldwide, and has been the global automotive sales leader since 1931. More information on GM can be found at www.gm.com.
LS7 specifications:
Part number: 17802397
Horsepower: 500 (373 kW) @ 6200 rpm
Torque (lb.-ft.): 475 (644 Nm) @ 4800 rpm
Engine type: Cam-in-block 90-degree V-8
Displacement (L/cu in): 7.0 / 427
Bore x stroke (mm/in) 104.8 x 101.6 / 4.125 x 4.00
Block: Cast aluminum with pressed-in cylinder sleeves and 6-bolt, forged steel main bearing caps
Crankshaft: Forged steel
Connecting rods: Forged titanium
Pistons: Cast aluminum
Camshaft type: Hydraulic roller, 15 mm (.591 in) lift (intake and exhaust)
Cylinder heads: CNC-ported aluminum; 70-cc chamber volume
Valve size (mm/in): 56 / 2.20 (titanium) intake / 41 / 1.61 (sodium-filled) exhaust
Compression ratio: 11.0:1
Rocker arms: 1.8:1; offset (intake only)
Recommended fuel: Premium required. 91 octane minimum
Later ... Larry S.
Later ... Larry S.
Good point.
On a side note what is a good cat back exhaust system to use that is an improvement over the stock ZO6 system.Magna Flow had a good impressive review awhile back in Vette Mag. with an X pipe as well.But that was with a C5 Coupe.My Vette mechanic swears by GHL pipes.
Looking for a mild HP increase and a more aggressive sound at idle.
took the words right out of my mouth...the ls7 HAS to fit because they used the c5 to test the engine
Sweet package in my mind
It sounds like it would come in at $15K or less....that is impressive
Long time no see buddy...
Will the C6 Z06 crate motor just drop in and will it include the PCM??
Anyone know or have some ideas??
Very curious to see what the $ will be and how hard it will be to install one of these in our cars...
I hope you are right...it just got sweeter if it is
