Strange message on my DIC...
Sometimes, when I start the car, I get a series of messages (paraphrased):
SERVICE ABS
SERVICE TRACT SYS
SERVICE ACTIVE HANDLING
If I shut the car off, then start it up again, the message goes away. And, as far as I can tell, the car seems to be driving normally. My active handling button and ride selector seem to still work.
Could all three of these things have actually gone out all at the same time? Or is there some other sensor/computer/electrical problem developing?
I've also been noticing lately, every once in awhile, my turn signals either don't work at all, or will just start blinking INSANELY fast. Don't know if that's related or not.
ABS / TC / AH Link
I hope that is not the case for you.
UT-Driven
So far it seems to go away on its own. Is this something that NEEDS to be fixed? Or is it merely a minor annoyance?
Thanks muchachos!~~~JadeDragon
i got it reset it and since the reset it hasnt came back... this is one thing about this car that bugs me sensors set off the ecu and the next day its perfectly fine and no codes are thrown...
You can swap the wire connections from right side to left and see if that is the issue.
-Chuck
I would start with the most simple and work from there and pray it's not the Brake Module, that's what mine was but TG I was still under warranty. This is a fairly common problem.Good luck
G101 left front frame (with SP101)
G102 right front frame (with SP100)
G103 left front of engine
G104 frame next to battery (with G108 & SP102)
G105 left lower engine block, engine ground strap & wire
G106 Battery negative pole
G107 Left rear head
G108 frame next to battery (with G104)
G201 bottom of A-pillar, left (with SP201 & SP203)
G202 bottom of A-pillar, rt, bolted at the bottom (with SP202)
G205 inside door pillar driver seat (with G301)
G301 inside door pillar passenger seat
G302 inside door pillar driver seat (with G205)
G401 left rear outer frame
G402 right rear inner frame
SP201 bottom of A-pillar, left (bolted with G201)
SP202 bottom if A-pillar, rt (bolted to G202)
SP203 bottom of A-pillar, left (taped to wire bundle, with G201 coming out of it)
G101: windshield washer fluid pump
Windshield washer fluid level switch
Brake fluid switch
Headlamp door assembly, left
G102: cooling fan, right
Cooling fan 3 relay 44
Horn assembly
Underhood lamp
Headlamp door assembly, right
Headlamp door control module
A/c compressor clutch
A/c compressor clutch diode
Secondary air injection pump
G103: Electronic brake control module (ebcm)
G104: battery negative pole
Splice pack SP102:
Marker lamp, right front
Marker lamp, left front
Park/turn signal lamp, right front
Park/turn signal lamp, left front
Turn signal lamp, right front
Turn signal lamp, left front
Splice pack SP208:
Body control module (bcm)
Instrument panel cluster (ipc)
Data link connector (dlc)
Inflatable restraint & diagnosis module
Inflatable restraint ip module disable switch
Park/neutral switch
Remote control door lock receiver
G105: fuel pump relay 35
Engine oil level switch
Heater O2 sensor, bank 1 sensor 1
Heater O2 sensor, bank 1 sensor 2
Heater O2 sensor, bank 2, sensor 1
Heater O2 sensor, bank 2, sensor 2
G106: battery negative pole
Ignition relay 42
Powertrain control modules (pcm, 4 wires)
Throttle actuator control module (tac)
Mass airflow sensor (maf)
G107: ignition control modules 1-3-5-7
Ignition control modules 2-4-6-8
G108: Electronic brake control module (ebcm)
G201: Splice pack SP201:
Air temperature actuator
Traction/suspension control switch
Driver door module (ddm)
Door latch, driver
Auxiliary power outlet
Windshield wiper motor
Steering column lock
Footwell courtesy lamp, left
Hazard switch
Telescopic actuator switch
Splice pack SP203:
Remote CD changer
Fuse block I/P
Speaker, right door
Speaker, left door
Radio
G202: Splice pack SP202:
Passenger door module (pdm)
Door latch, passenger side
HVAC control module
IP compartment lamp
Footwell courtesy lamp, right
Vanity mirror lamp, left
Vanity mirror lamp, right
Inside rearview mirror
Bose relay 45
Ignition switch
Blower motor relay c60
Blower motor control processor
Hood ajar switch
Cigar lighter
A/t shift lock control solenoid
G205: seat belt switch, driver
Seat control module (scm), driver
Seat pump, driver
Seat belt switch, driver
Seat relay center, driver
G301: defogger grid
G302: Splice pack SP302:
Seat relay center, passenger
Seat pump, passenger
Rear compartment courtesy lamp, right
Rear compartment courtesy lamp, left
Rear compartment lid latch
Rear compartment lid latch, right
Rear compartment lid latch, left
Folding top lid latch
Folding top release switch
Fuel door lock actuator
Radio power antenna
G401: Splice pack SP400:
Fuel pump & sender assembly, left
Fuel level sender, right
Tail, stop, turn signal, rear left
Tail, stop, turn signal, rear right
Center high mounted stop lamp
Backup lamp, right
Backup lamp, left
License lamp, right rear
License lamp, left rear
Marker lamp, left rear
Marker lamp, right rear
G402 electronic suspension control module (esc)
Check your grounds first.
Especially the G402 on the frame in the wheel well behind the Drivers Seat area.
There is a thread where someone posted scanned pics of exactly where all the grounding points are. I have cleaned up about 90% of them so far.
Had the same messages and I loosened, cleaned and retightened it and haven't had a problem since.
Just a thought.
Good Luck!
The warnings would pop up every once in a while and then disappear. Finally it was on constantly and I had to bring it to the dealer. Just picked up the car on Monday, they had to replace these parts:Part# 12216561 EBCM Moduel 4.720
Price: $935.72
Part# 10343432 BPMV Valve 4.730
Price: $1,645.92
Labor: $245.00
TOTAL: $2,826.64
Luckily I bought the extended warranty, this repair already more than paid for it!
Interesting suggestion about the battery - batteries here in Arizona do have an average lifespan of about two years, and I have had the car for almost two years, so I'm due...
Next question: If I replace the battery, what sort of radio-security-related problems might I encounter?
