Pucks
Old May 27, 2005 | 11:18 PM
Prosecutor's Avatar
Prosecutor
Default Pucks
Are jacking pucks supposed to come with the car? If not...why the hell not? Just curious. Two of my friends with C5s told me that their cars came with pucks. Could this have been a dealer "bonus"? I didn't get any...what about you?
Old May 27, 2005 | 11:23 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
No, they don't come with the car. I bought a set of 4 from a Forum vendor.
Old May 27, 2005 | 11:33 PM
KHM_70's Avatar
KHM_70
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Must have been a bonus -they didn’t come with my car.
The manual doesn’t recognize the frame’s lifting points either.
army2000's Avatar
army2000
St. Jude Donor '11
Yup, GM really pucked us over and left off the jacking pucks. What the puck is up with that??? Puck GM!!! Looks like you need to get all "pucked" up.
Old May 28, 2005 | 01:33 AM
GrayC5's Avatar
GrayC5
I did the same.
Old May 28, 2005 | 02:00 AM
VLVETTE's Avatar
VLVETTE
Make your own took me about 1/2 hour and cost less than $20 bucks for 4. I got 8 hockey pucks glued them together with JB Weld. Drill a pilot hole in the center and screw in a 1'' eye screw. I've seen these things going for over $50 (Corvette Tax)Puckem
Old May 28, 2005 | 06:45 AM
They do not come with the car. But, they probably should. Seems like the dealers don't have them to help protect the rocker panels.
Old May 28, 2005 | 08:45 AM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
Bought me a set from avender and a storage box from the Container Store, should have with the car like this!
Old May 28, 2005 | 08:50 AM
bernardomd's Avatar
bernardomd
Stupid question, but what is wrong with using a standard floor jack at the jacking locations specified by the manual? I've heard about using the hockey pucks for years, but I never understood why???
Old May 28, 2005 | 09:14 AM
Bat Boy99's Avatar
Bat Boy99
I would not get the plastic/polymer style lift pads. I had one fail and me and now my car is in the shop for $4100 dollers worth of repairs. Just lift the rear off of the pumkin. The front by driving up on some 2x4s to provide adequate clearance to lift off of the K-member. I learned the hard way. Hope fully you all can learn from my mistake.
Old May 28, 2005 | 09:28 AM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
and I use a piece of 1x6 as another precaution or jack up from cross members.
Old May 28, 2005 | 12:05 PM
jerrymcb's Avatar
jerrymcb
Because it is quite likley that the jack will be lifting against the
smc body panel damaging it. The pucks provide a solid interface
to the frame and clearance for the body panels to prevent
damage.
Old May 28, 2005 | 12:08 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
thats the ticket
Old May 28, 2005 | 12:17 PM
VLVETTE's Avatar
VLVETTE
I can't get a standard floor jack under my car. I had to get a low profile jack. I bought the Craftsman made the pucks and inserts for jackstands. And by the way I weight tested the jackstand inserts at over 3500lbs on one. They cost me about $15 to make and provide a good bearing surface for the puck. I jack using a 2x6 at cross member then stands at lift points or to lift just a tire I jack a lift points.
Old May 28, 2005 | 01:52 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Package it, sell it, retire off the profits. very smart ideas!!!
Old Jun 6, 2005 | 03:22 PM
CROWVETTE's Avatar
CROWVETTE
I just received today my BMW 318i pucks which are a perfect fit for the
C6. Once installed they stay on the car, so any moron can see where
to put the jack. You can not see them unless you are laying on the
ground looking under the car. $6.95 ea. plus a couple of bucks shipping. Thanks to a forum member that gave the info for ordering.
Old Jun 6, 2005 | 05:02 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I got them and they work great.
To Pucks
Old Jun 6, 2005 | 05:11 PM
Dave1998's Avatar
Dave1998
Please advise ordering information
thanks
Old Jun 6, 2005 | 05:40 PM
Shylor's Avatar
Shylor
Great idea! Have you come up with a way to make the inserts adjustable for height?
Old Jun 8, 2005 | 02:38 PM
SimonStern's Avatar
SimonStern
thanks
A quick search of CF results in:
www.BavAuto.com
part # 51 71 1 960 752
Click on jack supports and then go to 318i series
http://forums.corvetteforum.com/show...mw&forum_id=74
