making active handling OFF default???
Old May 29, 2005 | 08:40 AM
OkeeGuy's Avatar
OkeeGuy
Default making active handling OFF default???
my car handles MUCH better with it off...
can i make this the default setting???
Old May 29, 2005 | 09:15 AM
DeeGee's Avatar
DeeGee
You really sure you want to do that?
It saved me on one occasion and that's after 32 years accident free motoring. I've seen lots of stories here where Forum members have been grateful for the protection.
Inhibiting a safety feature should be a conscious decision in my book. JMHO.
Old May 29, 2005 | 10:31 AM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
http://www.laptrax.com/
I've used it for a year now. No problems. Easy installation. Manually override it if you desire.
Old May 29, 2005 | 10:46 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Are you sure about that? AH only intervenes when handling and steering inputs indicate you are exceeding the cars limits.
If you intentional want to slide the car then off is the way to go but for an extra margin of safety it will save your butt under most conditions.
Old May 29, 2005 | 11:22 AM
WillK's Avatar
WillK
If you are having handling problems than have that system checked out. You should not know it exists unless you are in trouble or on the track. It never takes control of the car unless it detects a problem.
Most people prefer Competitive mode or with AH turned off on the track, but unless I am really out of shape, it helps my times. (Then it shuts down the car which is a real let down)
It is really neat when you are struggling to make a corner and you feel the front brake on the turning side kick in and you actually make the corner. Formula 1 drivers who are the quickest in the world swear by their version active handling.
Old May 29, 2005 | 11:33 AM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
I dont think your handling problem is the active handling unless something is wrong with yours. The AH is a great feature and can only help under 99% situations don't tell me you drive the 1% all the time.
Old May 29, 2005 | 11:48 AM
Mr Snappy!'s Avatar
Mr Snappy!
Not a wise move young grasshopper !
(unless this is a full time race-car....at the track, that is )
Old May 29, 2005 | 12:45 PM
pewterwest99's Avatar
pewterwest99
Old May 29, 2005 | 01:40 PM
army2000's Avatar
army2000
St. Jude Donor '11
Don't do it!!! It's too easy to just turn off A/H when you hit the track. GM put it there to save your a$$ for those unexpected moments. Good luck.
Old May 29, 2005 | 03:05 PM
Old One's Avatar
Old One
Car handles MUCH better..........
Until you loose it!!
Old May 30, 2005 | 06:36 AM
OkeeGuy's Avatar
OkeeGuy
ok...i agree that it is better to leave it on...BUT...
for some reason my car acts twitchy on uneven or rough roads with it on...
so...there must be something wrong with it...
on smooth roads it is fine and normal...
turning it off on the crappier roads makes it handle MUCH better...normal...
BTW...it was aligned recently at the chevy dealer...
has anyone else here experienced this?
if something is wrong with the AH how would one tell?
would there be an error code i can search for?
thanx yall for your help and advice...
Old May 31, 2005 | 06:10 AM
OkeeGuy's Avatar
OkeeGuy
ttt
Old May 31, 2005 | 08:41 AM
PEW01's Avatar
PEW01
Old May 31, 2005 | 10:29 AM
InSaNeKaMeL's Avatar
InSaNeKaMeL
I dont even know what I'm missing my y2k frc does not have it, but I turn TC off all the time..
Old May 31, 2005 | 11:01 AM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Yep, I have one and love it. If you have a 2004, there are a few tricks to make it work but I finally figured that out. Mine stays on A/H which is actually the default setting for the laptrax. Good luck.
Jim
Old May 31, 2005 | 11:22 AM
ModRed405's Avatar
ModRed405
I don't understrand....does AH engage over "uneven or rough roads" in your car? Do you see it on the DIC?
AH is unobtrusive unless you are about to cross the limits of the tires and/or vehicle's handling limits.
Old May 31, 2005 | 11:39 AM
99 vett babycar's Avatar
99 vett babycar
GO TO LAPTRAX WEB SITE AND READ THE FAQ IF YOU STILL HAVE QUESTIONS ASK THEM - THEY KNOW WHAT THEY'RE TALKING ABOUT.
To making active handling OFF default???
