Skip Shift....
Old May 30, 2005 | 10:40 PM
Vette C5's Avatar
Vette C5
Default Skip Shift....
Does the skip shift come on all C5's?? and how exactly does it work
Old May 30, 2005 | 10:46 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yes.
They make you shift from 1st to 4th on part throttle. For fuel savings.
You can make your own CAGS delete for 50 cents or buy a ready made one for around 30 bucks.
Old May 31, 2005 | 04:11 AM
Shylor's Avatar
Shylor
Use the search function on the forum. This have been talked about many times already.
But if you just drive the car the way it was intended to be driven CAGS shouldn't bother you.
Old May 31, 2005 | 06:11 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
From the owners manual regarding the skip shift or CAGS (Computer assited gear selection).
When this light comes on,
you can only shift from
FIRST (1) to FOURTH (4)
instead of FIRST (1) to
SECOND (2). You must
complete the shift into
FOURTH (4) to deactivate
this feature. This helps
you get the best possible
fuel economy
This light will come on when:
- The engine coolant temperature is higher than
- You are going 15 to 19 mph (24 to 31 km/h) and
- You are at 21 percent throttle or less.
Old May 31, 2005 | 06:17 PM
This feature is on every C5. Get a CAGS eliminator, install it and shift away.
Old May 31, 2005 | 06:26 PM
JWB ZO6's Avatar
JWB ZO6
simple install takes longer to jack up than to install unless you have a lift.
Old May 31, 2005 | 06:38 PM
3318C5's Avatar
3318C5
Old May 31, 2005 | 06:49 PM
Shylor's Avatar
Shylor
Better yet just keep the rpms up before shifting. You won't go any faster than you normally drive to do this. Besides the Corvette was meant to be driven with higher revs. Grandma's don't drive Vettes.
Old May 31, 2005 | 06:50 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
It comes on all the 6 speeds, and what happens when you try to shift out of first under the conditions mentioned above is that a solenoid in the tranny blocks your access to 2nd or 3rd gear, forcing you into 4th. The CAGS eliminator mentioned blocks the signal to that solenoid, leaving you free to access whatever gear you want.
Old May 31, 2005 | 07:37 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
CAGS Eliminator was my first mod at something under 800 miles...
I seem to have gotten a little carried away since then.
I believe you can also avoid it by going back into neutral (clutch still on the floor) and then repulling to 2nd.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old May 31, 2005 | 07:44 PM
Richin Chicago's Avatar
Richin Chicago
Grandmas don't get stuck in stop and go traffic when the damm thing always picks the worst moment to lock out second gear. It's a 15 minute modification with a 2.2k 10 cent resistor.
Old May 31, 2005 | 07:49 PM
ghost.rider's Avatar
ghost.rider
Default Either
Drive it like its supposed to be driven
or
if you granny shift just let it take you over to the right and then bring the shifter back and put it in second, no muss, no fuss just leave the clutch in until you've made the complete trip, half way down, over to the right, back to the left and down into second.
The skip bypass was the first thing I bought for my C5 and it is still sitting in its bag somewhere in my house because I don't think we need it
Old May 31, 2005 | 08:34 PM
Shylor's Avatar
Shylor
Again......just let the engine rev up more rpms before shifting and CAGS won't activate.
Old May 31, 2005 | 09:22 PM
Richin Chicago
Or spend 10 minutes on the mod and run the car as the you want.
Old May 31, 2005 | 09:36 PM
Cpe04's Avatar
Cpe04
I agree. The cags eliminator is totally unecessary.
Old May 31, 2005 | 09:54 PM
magredZ51's Avatar
magredZ51
It's never activated on my C5, nor my F-body when I had it.
Old Jun 1, 2005 | 12:45 AM
Shylor's Avatar
Shylor
I know, CAGS is not even an issue with me when I drive my car. I guess for some reason everyone thinks you have to drive like a mad man using high revs to prevent CAGS from activating. This simply is not true. Test it out for yourself, it doesn't take much more rpms to prevent CAGS.
To Skip Shift....
