Engines Made in Mexico?
Old Jun 1, 2005 | 09:23 AM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Originally Posted by lemansbleu2004
Mine always seems to want to stop at Taco Bell!
Old Jun 1, 2005 | 09:31 AM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
I"ll post a break down of a forum members LS6 engine and other Vehicle Component .
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : K - GM OF CANADA, LTD. ST. CATHARINES, ONTARIO
Part/Num Broadcast : ZJA Traceability : 050040746
Date Scanned : 01/07/2005 Time Scanned : 08.22.00 Scan Station : 01
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : XJC Traceability : AA0743584
Date Scanned : 01/06/2005 Time Scanned : 10.58.00 Scan Station : 07
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 5YZD Traceability : 39683683
Date Scanned : 01/07/2005 Time Scanned : 09.30.00 Scan Station : 02
Component Code : 74
Source Plant : R
Part/Num Broadcast : 8460 Traceability : 433604020
Date Scanned : 01/10/2005 Time Scanned : 06.33.00 Scan Station : 08
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : M - DELCO ELECTRONICS MILWAUKEE, WISCONSIN
Part/Num Broadcast : YKWA Traceability : 043510VCE
Date Scanned : 01/10/2005 Time Scanned : 06.33.00 Scan Station : 03
Component Code : 87 - BODY CONTROL MODULE
Source Plant : R
Part/Num Broadcast : 0159 Traceability : A43450269
Date Scanned : 01/10/2005 Time Scanned : 06.33.00 Scan Station : 09
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 6358 Traceability : 4CAQRB1
Date Scanned : 01/07/2005 Time Scanned : 14.55.00 Scan Station : 04
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : I - INLAND
Part/Num Broadcast : 9907 Traceability : 3350A0021
Date Scanned : 01/06/2005 Time Scanned : 10.58.00 Scan Station : 05
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 2874 Traceability : 143550MTH
Date Scanned : 01/10/2005 Time Scanned : 06.33.00 Scan Station : 06
Component Code : AT - RIGHT SIDE IMPACT SENSING MODULE
Source Plant : X - DELCO ELECTRONICS SINGAPORE
Part/Num Broadcast : 2876 Traceability : 4338A0QLL
Date Scanned : 01/10/2005 Time Scanned : 06.33.00 Scan Station : 01
Component Code : AU - LEFT SIDE IMPACT SENSING MODULE
Part/Num Broadcast : 2876 Traceability : 4338A0QL8
Date Scanned : 01/10/2005 Time Scanned : 06.33.00 Scan Station : 02
Component Code : BK
Source Plant : K
Part/Num Broadcast : YJBM Traceability : 043560428
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 1150049
Date Scanned : 12/23/2004 Time Scanned : 00.33.00 Scan Station : N/A
Component Code : CF - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1YY Traceability : 0269532
Date Scanned : 12/23/2004 Time Scanned : 04.35.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1MM Traceability : 0269671
Date Scanned : 01/10/2005 Time Scanned : 06.31.00 Scan Station : N/A
And this is for a 2004 LS1
Vehicle Component
Part/Num Broadcast : ZHJ Traceability : 032101305
Date Scanned : 08/06/2003 Time Scanned : 10.54.00 Scan Station : 01
Part/Num Broadcast : XZJ Traceability : HH0521953
Date Scanned : 08/07/2003 Time Scanned : 07.14.00 Scan Station : 09
Source Plant : T - TREMEC MEXICO
Part/Num Broadcast : DFR Traceability : 023243
Date Scanned : 08/06/2003 Time Scanned : 12.10.00 Scan Station : 02
Source Plant : 9
Part/Num Broadcast : YFPZ Traceability : 032111JMP
Date Scanned : 08/07/2003 Time Scanned : 07.14.00 Scan Station : 03
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 4094 Traceability : YZAGN12
Date Scanned : 08/07/2003 Time Scanned : 07.14.00 Scan Station : 06
Part/Num Broadcast : 5724 Traceability : YZAFS50
Date Scanned : 08/07/2003 Time Scanned : 07.14.00 Scan Station : 07
Part/Num Broadcast : 0158 Traceability : 13196V66U
Date Scanned : 08/07/2003 Time Scanned : 07.57.00 Scan Station : 08
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 0230140
Date Scanned : 07/29/2003 Time Scanned : 00.33.00 Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : 1YY Traceability : 0218385
Date Scanned : 07/29/2003 Time Scanned : 04.08.00 Scan Station : N/A
Source Plant : N/A
Part/Num Broadcast : 1MM Traceability : 0218419
Date Scanned : 08/07/2003 Time Scanned : 08.24.00 Scan Station : N/A
Old Jun 1, 2005 | 09:32 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Originally Posted by army2000
Don't be too surprised. How many of you are willing to work 12 hours for a dollar a day????
Your mistaken...they make twice that
Old Jun 1, 2005 | 09:39 AM
MDog00's Avatar
MDog00
They were coming in from Mexico thru Arizona - Until the Minutemen started intercepting them
Old Jun 1, 2005 | 09:45 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Thanks Sponge Vette for the info
Old Jun 1, 2005 | 10:14 AM
C6 NOIR's Avatar
C6 NOIR
St. Jude Donor '03-'06-'07-'08-'09
Knew there must be a reason for my license tag being in Spanish.
Old Jun 1, 2005 | 10:40 AM
vetdude's Avatar
vetdude
Fact - Rear diff made in Mexico, thus the leakage problems from poor gasket material!
Old Jun 1, 2005 | 12:04 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
Mine clearly states "Made in Bowling Green, KY" USA.
Old Jun 1, 2005 | 12:29 PM
WaWaTuSi's Avatar
WaWaTuSi
St. Jude Donor '05
I was wondering what that "hecho en Mexico" meant on the engine block!
J/k
Old Jun 1, 2005 | 12:40 PM
SavPrato's Avatar
SavPrato
Originally Posted by Zilla
I know for a fact that the LS1 were made in St Catherine Ontario.
Old Jun 1, 2005 | 12:46 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
St. Jude Donor '08-'09-'10-'11-'13-'14
Originally Posted by PEW01
I would find it hard to believe, any car, is 100% made in the USA.
Might be why the sign says "Bowling Green Assembly" and not manufacturing.
Old Jun 1, 2005 | 01:14 PM
Tom73's Avatar
Tom73
Originally Posted by C5VetteLS1
I was talking with a couple of C5 owners in Palm Desert yesterday about the C5 & C6 Vettes. The one guy mentioned that the engines used in later C5's and the new C6, were made in Mexico. Is there any truth to this, or is it total
The LS1 is built in Canada. But the old "classic" Chevy small block (the current crate engine) is cast and built in Mexico.
tom...
Old Jun 1, 2005 | 03:50 PM
  #33
Benpup's Avatar
Benpup
Must be. When I squash on the long loud pedal it sounds like it's saying On-do-lay, on-do-lay.
At least it's not Spanish Rice.
Old Jun 1, 2005 | 04:01 PM
  #34
Benchpress's Avatar
Benchpress
My engine is stamped EAT MORE RICE!
  #35
Fast98's Avatar
Fast98
http://www.ls1.com/forums/showthread...exico+assembly Don't be too surprised. How many of you are willing to work 12 hours for a dollar a day????
We will have to if we want to compete
Old Jun 1, 2005 | 05:20 PM
  #36
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
I posted this in C6 General as well. They're telling me that their Engines are built in Canada and that the Transmissions are built in Mexico.
Old Jun 1, 2005 | 05:43 PM
  #37
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
At least it's the Continent of North America.
To Engines Made in Mexico?
Old Jun 1, 2005 | 05:52 PM
  #38
b98's Avatar
b98
Old Jun 1, 2005 | 06:12 PM
  #39
jdmvette's Avatar
jdmvette
Night Owl for life
Maybe they're made in Santa Poco.
Old Jun 1, 2005 | 06:58 PM
  #40
SLPRC5's Avatar
SLPRC5
Mine will run on Cuervo Especial Tequila
Just kidding..who knows or cares runs damn good!
