Headlight Problems
Old Jun 1, 2005 | 06:07 PM
maacoman's Avatar
maacoman
Default Headlight Problems
Hi Guys,
This morning I went to put my parking and fog lights on because of rain, and my headlight doors opened which they never do,and when I went to close them they make a grinding sound after they have closed which lasts for about 8 seconds. What do you think...
03 Vert
John
Old Jun 1, 2005 | 06:18 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Your gear is going out on the actuator. You have three choices here:
1. Have the dealer replace the actuator for approximately $300, which is what I was quoted.
2. Buy a new actuator for approximately $175 and replace it yourself.
3. Order a brass gear from Rodney Dickman's and rebuild it yourself.
I did the rebuild for $45.
Good luck with your decision.
Old Jun 1, 2005 | 06:54 PM
maacoman's Avatar
maacoman
Thanks for the info, I will rebuild them, if thats all it costs with the bronze gears which are I would think alot better
John
Old Jun 1, 2005 | 06:58 PM
finnor's Avatar
finnor
You too?
http://forums.corvetteforum.com/show...7&forum_id=103
--Tor
Old Jun 1, 2005 | 10:13 PM
maacoman's Avatar
maacoman
Yea, it was the weirdest thing to hear.It sounded like a plastic fan against my radiator
John
Old Jun 13, 2005 | 07:36 AM
BLKBTY's Avatar
BLKBTY
Default Removing headlight actuator motor?
Hi Guys,
I have an 89 that the passenger headlight comes up at a different time
than the other one. I see where you can rebuild the motor, but I need to know how to remove the bad one. Please reply a fix.
Blkbty.
Old Jun 13, 2005 | 08:07 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
yea...pick three... pick three
To Headlight Problems
