Need some Clay Bar tips....
Old Jun 1, 2005 | 10:14 PM
VETTE2k's Avatar
VETTE2k
Default Need some Clay Bar tips....
So what is the best way to clay bar your car?
I would like to get my C5 clean, I haven't kept up on wax...and I want to clay it before I wax it again.
So what do you do?
Just run the bar over your car with a hose running on it? Or do you soak it in water every now and then?
Those who have done it a few times, what are some good tips you have picked up?
I don't want to ruin my paint job, can you really screw it up with a clay bar, or are they idiot proof?
Thanks.
Old Jun 1, 2005 | 10:17 PM
jrose7004's Avatar
jrose7004
Wash the car with dish washing soap to get what wax there is off. Then clay the car in small sections using the lube in the spray bottle you get with it! It's easy really!
Old Jun 1, 2005 | 10:22 PM
rickko's Avatar
rickko
So what do you do?...
Everyone probably has their own method but here's what I do.
I bought the Mother's kit that includes the claybar. Also includes some Detail wax.
I follow their instructions which says, wash/clean car. Dry car. Spray the detail wax (liquid) in a 2'x2' area. Run clay bar over sprayed area back and forth. Take a soft terrycloth towel and buff it out.
This works well, as you are claybar-ing and putting a little Detail Wax on at the same time. Boy does the surface feel good afterward; unbelieveably smooth.
DON'T DROP YOUR CLAYBAR ON THE GROUND!
That's it!
Good luck!
..rickko..
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Here's a few things = beyond these I'd suggest you take a look in the car care section - it's all about this stuff.
First, was completely. If you want to strip any leftover polish, use Dawn dishwashing detergent in water - otherwise, use a good car care soap.
Then dry car off
Next, using a detailing spray (NXT) or car wash soap in water (Zaino) gently work a small area of the car in a back and forth pattern (others may suggest circular) with the clay bar only putting very light pressure on it, and keeping it well lubricated. You are trying to capture small particles of contaminants lodged in the clear coat, not sand it. Once you do not feel any snags as you go over your small section, move on to the next area. Fold the clay frequently and lube often.
Old Jun 1, 2005 | 10:52 PM
ECV-Tony's Avatar
ECV-Tony
Dawn wash, use a spray bottle with car wash soap in it to keep the surface moist and slippery. Rub the clay bar along the surface until it is completely smooth, keep spraying soapy water. I thoroughly clay each section around the car so nothing is missed. Then rewash your car with your fav car wash and polish or wax with your fav product. As long as you stick with the same polish/wax you don't have to dawn wash when you clay anymore. Just if you change from say a wax to a polish.
After you are done shining up your ride have a cold one!
Old Jun 1, 2005 | 10:54 PM
ECV-Tony's Avatar
ECV-Tony
BTW...fold your claybar often.
Old Jun 1, 2005 | 11:07 PM
Z0SLIK's Avatar
Z0SLIK
I agree!!
Old Jun 1, 2005 | 11:55 PM
Todd@EastCoastCorvettes's Avatar
0Todd@EastCoastCorvettes
Former Vendor
check out this informative video on clay bar....
clay bar video
Old Jun 2, 2005 | 12:30 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Everything ECV said & check out the car care section.
Old Jun 2, 2005 | 12:39 AM
DaBoz's Avatar
DaBoz
clay bar video
Good vid.... the only thing I do that is different is: I break off a small piece of clay, enough to make a flat silver dollar sized piece to use. Very thin. When one side is dirty, turn it over. When the other side is dirty, throw it away. This way you never have to worry about the contaminants in the clay scratching the clear coat.
Old Jun 2, 2005 | 12:41 AM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
Lots of great information.
Old Jun 2, 2005 | 12:45 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Saving link as a favorite
Old Jun 2, 2005 | 12:47 AM
diverdan's Avatar
diverdan
The Mothers kit is fool proof, especially if you are a first timer (as I was). The results were astonishing; I didn't see much difference visually (quicksilver paint), but the car felt like it was made of glass.
It made me a believer.
Old Jun 2, 2005 | 12:48 AM
ECV-Tony's Avatar
ECV-Tony
This is important too...
If your doing this for the first time, you may want to lay something between your claybar and the ground. Those claybars get real slippery...
Old Jun 2, 2005 | 12:53 AM
lager99's Avatar
lager99
St. Jude Donor '06
You WILL drop it...throw it out!
Old Jun 2, 2005 | 12:56 AM
ECV-Tony's Avatar
ECV-Tony
...or you will risk scratching your paint. Which is why I recommend something between the ground and claybar...
Old Jun 2, 2005 | 01:01 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
That's it!
Good luck!
..rickko..
Just keep sparying the clay bar and ensuring that it is nice an wet too! I love clay barring my car at least twice a year. It really cleans the surface!
Have fun and be ready for a solid three hour job!
Micah
To Need some Clay Bar tips....
Old Jun 2, 2005 | 01:10 AM
SPD KILZ's Avatar
SPD KILZ
Maguires gold class soap has a lubricant especially for claybaring your car. I wash it then wet down the area im going to bar with lots of suds and water then go to town. The trick is to keep it well lubricated.
Old Jun 2, 2005 | 01:49 AM
StingerZ16's Avatar
StingerZ16
Great link!
Going through all the videos. Good basic info but still good to have reinforcement from time to time.
Old Jun 2, 2005 | 02:04 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
I did mine when I washed my car ... Just used the water as the lub ... came out great IMO.
