Need some Clay Bar tips....
Old Jun 2, 2005 | 08:12 AM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
1st of all Dawn does not take off wax unless you want to wash your car about 6 or 7 times in a row.
That does not matter becuase the clay bar will remove everything including the wax and you will be very happy.
All clay bar kits include a spray detailer as a lube ( dont use water and soap you wont get the same results).
Pull off part of the clay bar and soften by working it in your palm. Flaten to about the size of a half dollar and proceed with wetting the area ( fender, door , hood or quater at a time) with the detailler and proceed as if you were washing that section. Turn the clay often to keep the clay clean against your car.
Many environmental contaminants adhere to your paint so strongly, that even a high-quality car wash cannot remove them. Some may be visible to your eye. Others you'll detect when you pass your hand across the finish after washing and notice it doesn't feel as smooth as glass.
All of these contaminants can reduce your shine and ultimately do permanent damage to your paint. A safe, non-abrasive clay bar and high lubricity quick detailer like those found in Meguiar's Quik Clay System will safely remove above surface, bonded contaminants, quickly and easily. (Never use sharp, abrasive rubbing and polishing compounds that will scratch your car's finish.)
Old Jun 2, 2005 | 08:20 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
good info here...
Old Jun 2, 2005 | 08:30 AM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
Originally Posted by lager99
You WILL drop it...throw it out!
Griots have a really nice holder that does a great job....and can be used with your Portercable or by hand.
Old Jun 2, 2005 | 08:33 AM
ArmyVette's Avatar
ArmyVette
In addition to all of the good advice and links posted above, here's my $.02 worth.
After I was the car, I leave the car wet. After claying, I was the car again to remove any clay residue.
While using the clay (in fact, during the entire detailing process), I wear non-talc rubber gloves. You can get a box of 100 from WalMart, CVS, etc., for about $5. Rubber gloves help you hang on to that slippery claybar.
Old Jun 2, 2005 | 08:36 AM
bagwell's Avatar
bagwell
Originally Posted by Todd@EastCoastCorvettes
check out this informative video on clay bar....
clay bar video
hummm I didn't know you can clay bar the windows as well.
good info.
Old Jun 2, 2005 | 11:08 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Just make sure you keep it wet with whatever solution you chose fi not you can end up witha real mess on your hands.
Old Jun 2, 2005 | 11:18 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
I can't add to the experts here...but my experience I found that you cannot have enough lubricant, and you can have too little, be careful and use lots . And next time I claybar i will do the bottom of the car last, like washing. You will find behind wheel areas gets the bar dirty VERY quickly. JMO Good Luck
