whats a multi-function switch>>??
Old Jun 7, 2005 | 10:31 AM
m3amg43's Avatar
m3amg43
Default whats a multi-function switch>>??
I need to change the multi-function switch on my C5, can someone tell me what exactly that is?? And how to replace it. sorry for rhe dumb question!
Old Jun 7, 2005 | 10:36 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
A mutifunction switch is one, which when repeatedly pressed, toggles through different functions. Kinda like the DIC buttons on the right side of you dash (i.e. FUel, Trip, etc.).
Which one do you have to replace?
BTW, there are no dumb questions ... only dump people.
Old Jun 7, 2005 | 10:40 AM
m3amg43's Avatar
m3amg43
hmm... What does the multi-function switch have to do with my dash not illuminating?? check out his thread..
http://forums.corvetteforum.com/show...396&forum_id=1
Old Jun 7, 2005 | 10:44 AM
MyVetteDream
Ohhhhhh. No there is no multiswitch.
On the left side of your dash is the dimmer switch (the little round one). That's the one that controls the brightness of the lights you're having issues with. Turn that to the right (clockwise) and see if that solves your problem. Let us know if it works.
Old Jun 7, 2005 | 10:46 AM
m3amg43's Avatar
m3amg43
I tried that, I mean the interior lights work perfect, when i put that switch up all the way past the click, the interior lights go on, but still no dash lights while the headlight is on. (climate control doesnt illuminate, and the cluster doesnt illuminate)
Old Jun 7, 2005 | 10:52 AM
MyVetteDream
Hmmm ...
Go to the fuse box in the passenger side footwell and start checking fuses. #19 is the Instrument Panel Control ... it may have something to do with illumination. Otherwise, get yourself a fuse tester and start checking the others. If you were close I'd loan you mine. They're only a couple of bucks at any autoparts store.
Old Jun 7, 2005 | 11:04 AM
m3amg43's Avatar
m3amg43
OK I will check fuse 19 right now, I mean I have 2 corvettes so i can take parts out of my 98 and see what happens. Maybe this will help, when I turn the headlights on in my 98 I hear a click inside the car, on the 97 I dont hear a click, does that have something to do with it>? BRB... I am gonna check fuse 19 right now
Old Jun 7, 2005 | 11:08 AM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
On most cars the multi-function switch is usually one of the stalk-mounted levers.
Old Jun 7, 2005 | 11:13 AM
MyVetteDream
Relays are what click. I wonder if your relay's bad. More huntin' for electrical gremlins.
Old Jun 7, 2005 | 11:24 AM
m3amg43's Avatar
m3amg43
just checked fuse 19, when I took it out, I got a message that said "low voltage" I dont think it is the fuse. ANyhow I chnged the fuse just to be sure.
Old Jun 7, 2005 | 07:04 PM
Tim downs's Avatar
Tim downs
Cruising
i have the same problem. My dash lights and fog lights do not work when I turn on my lights manually. If I use twilight sentenial then my dash lights work. I tried changing my flasher unit and checked my fuses but that did not work.
To whats a multi-function switch>>??
