Visor Vanity Mirror?
Old Jun 9, 2005 | 07:17 AM
JLA's Avatar
JLA
Default Visor Vanity Mirror?
The passenger side one was about to fall off...loose at the the top part. I glued and clamped it, but the only thing to glue it to was the fuzzy material of the visor. It sags less, but still sags. I flip the visors down to hold the windshield sun shield in place, so that's not helping it. How are these things originally attached?
Old Jun 9, 2005 | 07:39 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I did the homelink install a year or so ago that involved opening up the visor at the seam. If memory serves me, the mirror assembly simply sits in a "cardboard" (Yes the General went all out) type of frame. Sounds like that frame has weakened. There is an excellent writeup in the Tech section about removal of the visor and homelink install. Grab those and you have a really good overivew of the assembly.
Old Jun 9, 2005 | 07:43 AM
Flying Ace's Avatar
Flying Ace
St. Jude Donor '05-'06
I had the same problem a couple of weeks ago. My daughter pulled down the visor and the vanity mirror snapped loose hanging by the wires.
It's held on by several plastic pins that fit (and I believe lightly glued) into the visor itself. The pins are less than 1/8" thick. If memory serves correctly, theres about three pins top and bottom and a couple on each side.
I got a replacement from Laura "tailights" here on the forum. I think you're better off replacing it.
Old Jun 9, 2005 | 07:50 AM
not08crmanymore's Avatar
not08crmanymore
Default visor
well,it's a relief to know that my 01 isn't the only one with visor issues,blinker issues,and like that!my pass.side visor got like that a month ago,haven;t replace it yet because nothing is as simple as it looks and with just a quick glance i can see i need to remove framulator and disconnect the perculator etc... and c5blackbeauty,you were right on time with the visor you sold me!!!thanks!so,getting back to reality here,i may see what crazy glue will do,or just take some time this weekend and replace it.oh,the driver side is now loose too! this really does feel like a race car with all these little things breaking/coming undone!!!i should be a master mechanic by the time i'm done w/this car!!
Old Jun 9, 2005 | 08:00 AM
duds's Avatar
duds
Default 2000 Visors
I need both visors for my 2000 cp. Is Laura "Tailights" a forum vendor? Any suggetions as to the best place to obtain replacements? My local dealler wanted $118.00 EACH !!! Thanks Duds
Old Jun 9, 2005 | 03:28 PM
Flying Ace's Avatar
Flying Ace
Not that I'm aware of.
Send her a PM. I got mine for $50.00 and it's like new.
Old Jun 9, 2005 | 05:35 PM
ebubman's Avatar
ebubman
good info; this is precisely why we read & contribute to these forums. good stuff!! bub
Old Jun 9, 2005 | 05:58 PM
JBH's Avatar
JBH
Mine broke a couple of months ago. Ordered a new one from Fitchner for about $60. Replacing it took 5 minutes.
To Visor Vanity Mirror?
