A4 Shift Knob Replacement
Old Jun 10, 2005 | 05:03 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Default A4 Shift **** Replacement
Has anyone replaced the shift **** on their A4? If so, would you please send me instructions/pictures on how to get the original one off? The sheet I received from the vendor is difficult to read and doesn't make a lot of sense.
Thanks.
Old Jun 10, 2005 | 05:12 PM
C5starman's Avatar
C5starman
CI 7-8 Veteran
I did it, but I don't recall the exact steps. It was not a problem. Instructions are in the Tech Tips. Look at the top of the page - click on Other. Click on C5.
I had the A4 adapter kit so I could install **** made for standard shift cars. Instructions for that came with the ****.
Old Jun 10, 2005 | 05:35 PM
BubblePuppy
I looked in the Tech Tips section, but the article there was for a manual shift **** replacement. Thanks for replying, though.
Old Jun 10, 2005 | 05:54 PM
C5starman's Avatar
C5starman
CI 7-8 Veteran
Sorry I mis-directed you. There is a retainer 'pin' at the bottom front of the ****. I pried that out with a thin screwdriver. I think the **** just unscrewed after that, but maybe someone with more functioning brain cells will respond.
Old Jun 10, 2005 | 06:43 PM
Blue Lion's Avatar
Blue Lion
I've thought about replacing my A4 know but I can't find a replacement that I really like. Any suggestions?
Old Jun 10, 2005 | 06:46 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
It's actually realllly easy.
Just look at the ****, the face between the **** and the HVAC. You'll see a horizontal metal piece. That's a giant staple ... pry it out with a small (very small) plathead screw driver. The **** pops right off.
Blue Lion ... I like the Razo **** ...
Old Jun 10, 2005 | 06:48 PM
Dave68's Avatar
Dave68
http://www.cau-llc.com/shiftknobinstall.html
This company also sells the adapter. If you happen to like translucent colors, check out www.conceptualpolymer.com
The locking collar is not required, but a slightly different thread and counterbore depth is required and available at no extra cost.
98NassauBluC5's Avatar
98NassauBluC5
From: I'm a Texan, but I traded the horse for the Vette.
It'll stand a little higher, but oh the difference.
Old Jun 10, 2005 | 08:12 PM
azmusclecar's Avatar
azmusclecar
I thought I saw a nice aluminum handle with STu'sVette on it I liked...but $135.00 is a bit much for me right now. I am mod broke........YES AGAIN as I answered my wife too!
Old Jun 11, 2005 | 04:05 AM
FiberglassFan's Avatar
FiberglassFan
Gotta watch the spelling......
".....pry it out with a small (very small) plathead screw driver. The ****......"
Shouldn't that be "phlathead"
Going by the example of my Price Phister phaucet
Seriously though, I too have an A-4 and am interested in possible improvements over the stocker.
Old Jun 11, 2005 | 04:34 AM
Maniac's Avatar
Maniac
I have tried several ***** for my A4 and haven't liked any of them. I don't want it higher than what it is either! Someone needs to make a stylish **** that fits without adaptors!!
Old Jun 11, 2005 | 04:38 AM
slverc5's Avatar
slverc5
Thanks.
Just like a few of the members here said. Put your key in the ignition, put it on start but don't start it, this way you can move your shifter from P all the way to D and look at the bottom part of the front part of the shift ****. Like the others said, you will notice a small metal piece which you could pry out with a small and I mean use a small flathead screwdriver and carefully pry it out, once you pry part of it, instead of pushing it out with a bigger flathead, use long nose pliers, reason for this is sometimes if you just use a bigger flathead after prying part of it out, it jumps out and you may lose the small staple like metal clip. All in all, it just takes about 5 mins of your time. Hope this helps.
Old Jun 11, 2005 | 05:39 AM
FiberglassFan
Default !!!!
I agree!!!!!!!!!!!!!!
Old Jun 11, 2005 | 05:54 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I REALLY like this one..........[IMG][/IMG]
To A4 Shift Knob Replacement
