Bilstein sports make all the difference
Old Jun 11, 2005 | 01:02 PM
torch2000vert's Avatar
torch2000vert
Default Bilstein sports make all the difference
I just installed a set on my 00 Vert, and it transformed the car! Gone is the float and uncontrolled feeling on uneven pavement. The ride is about 10% firmer handling is about 20% flatter. It really quieted down the rear as well. I bought them from Shox.com for under $300. The best $300 I have ever spent
Old Jun 11, 2005 | 01:44 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Nice! Sounds like a raving review
Old Jun 11, 2005 | 01:46 PM
WKMCD's Avatar
WKMCD
Bilsteins and Z06 bars here. Add a Z06 alignment or something more aggressive than the stock C5 alignment and the fun really begins.
Old Jun 11, 2005 | 01:48 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Ohhhh yeaaaah
Old Jun 11, 2005 | 01:53 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Torch, do you have base or Z51 suspension? How many miles were on the old shocks?
Old Jun 11, 2005 | 06:12 PM
VetteSiNz's Avatar
VetteSiNz
Awesome deal! I can't wait to replace my base suspension. Hotchkis Sway bar arrived today via the white truck, courtesy of Corvette Garage and Z06 springs/Bilstein Sports next week via the brown truck. It's mod time.
Old Jun 11, 2005 | 08:43 PM
Good deal.
Old Jun 11, 2005 | 08:45 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Had them on 86 vette, awesome ride .................
Old Jun 11, 2005 | 09:42 PM
pewterwest99's Avatar
pewterwest99
Anyone do this to an F45 suspension?
Old Jun 11, 2005 | 10:24 PM
MyOwn69's Avatar
MyOwn69
They list two - regular and heavy duty.
Which did you get?
Old Jun 12, 2005 | 01:29 AM
NitrousMan's Avatar
NitrousMan
Which are better Bilstein or ZO6 shocks?
Old Jun 12, 2005 | 01:30 AM
FLYNAVY30's Avatar
FLYNAVY30
so whats the best set up....bilstein shocks w/ Z06 springs and the Hotchkins sway bars?? Or are you better off going with the straight up Z06 set up
Old Jun 12, 2005 | 02:03 AM
98Z51's Avatar
98Z51
I installed some on my 98 a few weeks ago along with a Z06 alignment. It feels much better now, and while the ride is a little more firm, it's not uncomfortable at all.
Old Jun 12, 2005 | 02:05 AM
Dave68's Avatar
Dave68
I'll bet he didn't have the Z51. I never heard anyone call the Z51 "floaty"!
Old Jun 12, 2005 | 04:01 AM
torch2000vert
My car had the base suspension, 6300 miles, I'm not sure of the option number of the base package. I Hotchkis bars on my A6, was planning getting a set for the c5 but the bilsteins flattened it out so well I think I will just add the ZO6 bars and solid endlinks. Picks comming soon of 18x9.5 and 18 x10.5 Afs polished ZO6 replicas.
Old Jun 12, 2005 | 06:53 AM
Z0SLIK's Avatar
Z0SLIK
Good deal!!
Old Jun 12, 2005 | 08:38 AM
mark b's Avatar
mark b
What is a Z06 alignment? Do you have specs? When I got my C5 aligned they just set it to factory specs...what is the difference?
thanks
To Bilstein sports make all the difference
Old Jun 12, 2005 | 10:20 AM
yellow01's Avatar
yellow01
thanks
Z06 alignment is a little more agressive with a bit more negative camber and may include some toe differences (I don't have the sheet in front of me).
Stock C5 alignment is pretty much with everything at 0*, which straight driving on the freeway makes the car feel like it's on rails, but begins to fall short under cornering or track conditions.
Honestly though, while the Z06 alignment is a little more agressive and will get you some, unless you need one anyway I personally would not spend the $$ just for that. Also, if you're running run flats you don't want much if any neg camber. With non runflats it's ok.
I went from a neutral stock alignment to -1.5/-1 camber front and back with front toe out and rear in (all other things equal including the track) and the handling difference was rediculous. Drawback is I'll have to flip tires but that's easy enough.
Old Jun 12, 2005 | 10:27 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
The Z51 is the adjustable one, right? The one with the button that says sport, performance and ... damn, gotta go outside to see what the third setting is.
Anyway, the three setting one is the Z51, not the F45, right?
If so, what is the F45 option?
Thanks,
Mark
Old Jun 12, 2005 | 11:21 AM
yellow01's Avatar
yellow01
F45 is the mag selective ride control, or the adjustable.
Z51 is a track oriented option with stiffer springs, thicker sway bars and a power steering cooler.
