low coolant message
Old Jun 15, 2005 | 08:28 PM
AndrewNguyen's Avatar
AndrewNguyen
Default low coolant message
what kind of coolant should I be putting in my vette, do i have to drain the old fluid or just pour more in, never done it before?
Thank you,
Andrew
Old Jun 16, 2005 | 01:30 AM
GrayC5's Avatar
GrayC5
GM recommends that a 50/50 mixture of ONLY GM Goodwrench DEX-COOL or Havoline DEX-COOL silicate-free coolant and clean drinkable water be used. Using other coolants can result in premature engine heater core or radiator corrosion. DEX-COOL extended life coolant, according to GM, should be good for 5 years or 150,000 miles whichever occurs first. If your car is a '98 and still has the original coolant, it's past time for a change. All this should be covered in Section 5, Service and Appearance Care, in your Owner's Manual and you may want to read what it has to say on adding/changing Coolant along with the cautions. Hot coolant is under pressure and can cause severe burns. So, if you haven't done this before and are not sure how, you may want to let someone that knows do it. Good luck.
Old Jun 16, 2005 | 07:14 AM
What GrayC5 said. You do not need to drain old fluid out to add new fluid, just be careful if the car is hot.
Old Jun 16, 2005 | 10:36 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
What year? Mileage?
Get a Power purge, it replaces all the fluid. $150 @ Dealer.
Are you getting the low coolant message? If you are and the bottle is full, check the sensor. They are known to fail easy.
Old Jun 16, 2005 | 11:49 AM
RedRider98's Avatar
RedRider98
Are you getting the low coolant message? If you are and the bottle is full, check the sensor. They are known to fail easy.[/QUOTE]
How do you check the sensor? I got this message once the other day and the bottle is full!
Old Jun 16, 2005 | 11:56 AM
Postergeist's Avatar
Postergeist
I've gotten the low coolant messages before, but it was low.
Here's another for ya (just in case this happens to you and you're, like, WTF?): Coolant temp goes from 220 to 260 instantaneously, then back down to 220...then back to 260. Nope, not overheating. You could see air bubbles in the nozzles going into the coolant reservoir. I ran the car with the reservoir open and it resolved itself (oh, and topped off with coolant).
Old Jun 16, 2005 | 12:58 PM
AndrewNguyen
no it still says full, must be the sensor. How can I replace it and the cost?
Thank you,
Andrew
To low coolant message
