keyless entry remote issues
Old Jun 15, 2005 | 09:10 PM
kevo187's Avatar
kevo187
Default keyless entry remote issues
I have a 1997, even after placing a new battery on my remote, it stops working. any ideas, will buying another help, is it more than just the remote? please help
Old Jun 15, 2005 | 09:13 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Try a relearn though the DIC
Old Jun 15, 2005 | 09:35 PM
kevo187's Avatar
kevo187
what is the DIC?
Old Jun 15, 2005 | 09:36 PM
Vertigo's Avatar
Vertigo
DIC = Driver Information Center
It shows all the various functions of the car. i.e. miles, tire pressure, mpg etc.
The manual explains its full use.
Vertigo
Old Jun 15, 2005 | 09:46 PM
DC-STRO's Avatar
DC-STRO
From: After reading this thread, I gotta tell ya... you're an ass. .
St. Jude Donor '05-'06-'07-'08-'09-'10-11-'12-'13
Try this....
Resetting and Reprogramming Keyless Entry Remotes
To reset a keyless entry remote, stand in range of the car and hold the "Lock" and "Unlock" buttons for 10 to 12 seconds. If it resets, the horn will sound and the remote will work again. If this does not work, follow the procedures below:
1) Turn on the ignition, but don't start the engine.
2) Press "Reset" button in order to clear any IPC display warning messages.
3) Press and release the "Options" button on the Driver Information Center (DIC) to scroll through the display options until the IPC display is blank.
4) Press and hold the DIC "Reset" button for 3 seconds until the FOB TRAINING message appears.
5) Press "Reset" once again and it will ask you to hold the "Lock" and "Unlock" buttons on the first remote. (Corresponds to Memory button one, if you have the memory option)
6) The horn will sound, indicating the remote frequency has been learned.
7) Repeat the process for the next remote. You can have up to 3 remotes per car.
To keyless entry remote issues
