Blackwing question
Old Jun 17, 2005 | 08:31 PM
3RD-INF's Avatar
3RD-INF
Default Blackwing question
About how many miles can I expect to get, before my Blackwing need to be cleaned and reoiled? It's been on about 14,000 miles, and has never seen a gravel road. Thanks in advance.
Old Jun 17, 2005 | 09:25 PM
Larry_Yerton's Avatar
Larry_Yerton
It should have an indicator valve on it. When I got mine I was told since AZ is so dusty and the dust is very fine that I should clean it at least every 10k.
Old Jun 17, 2005 | 09:32 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Mine had been on nearly 20K mi when I just cleaned it. It was moderately dirty but the indicator still showed green. I think it depends on the type of driving you do and the part of the country you're in.
Old Jun 18, 2005 | 02:16 AM
3RD-INF's Avatar
3RD-INF
Mine is still showing green. I try to avoid dusty roads when ever I can. I did open up the area behind the fog lights. That caused the engine area to get a little dirtier than normal. I'm taking it next Wednesday on my trip to Flordia from the K.C. area. Hopefully the little red button won't pop-up on my trip. I just might clean it before I leave, just to be on the safe side. Thanks for all the imput. Gary
Old Jun 18, 2005 | 07:13 AM
I'm not sure just how accurate the indicator is - I just do a visual check each time I wash the car to see how dirty the filter is getting. So far, no need to clean with better than 10K on the filter.
Old Jun 18, 2005 | 07:55 AM
Lancer033's Avatar
Lancer033
I had about 20k on mine the 1st time I cleaned it, but now I'm doing it once a year.
Old Jun 18, 2005 | 11:50 AM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Awesome...I was just about to ask this question - I've got a little under 20k on mine and the indicator has barely moved.
Old Jun 18, 2005 | 11:59 AM
rickko's Avatar
rickko
Well the Blackwing literature says, "Cleaning your Blackwing high performace air filter is recommended between 50,000 and 100,000 miles on typical driving applications."
Only in OFF-ROAD conditions does it recommend you pay closer attention to it.
So, I'd say relax, enjoy your trip; even your whole summer until you've put over 50k on it or taken it off-road, which ever comes first.
Its warrantied for 10 years using that cleaning schedule.
I'd think the little pop up indicator is there for a reason. Why not let it be your guide?
..rickko..
Old Jun 18, 2005 | 03:06 PM
3RD-INF's Avatar
3RD-INF
..rickko..
That's sounds good to me. Thanks for all the info. And I will enjoy my trip. Gary
To Blackwing question
