Does this really work?
The flow rate does not change...i.e. the amout of air molecules that go from outside the intake to the engine does not change. The same amount of air goes in one end as comes out the other. Sure the velocity increases, but the flow rate will not. Like putting your thumb over the hose...sure water forces out stronger but it takes just as long to fill a bucket.
How does the physical velocity (m/sec not moles/sec) of the air into the TB affect HP?
Exactly what I've been trying to say. Thanks yellow01.
The higher velocity probably only helps with the air/fuel mix, maybe, higher velocity, better mix? Also a higher velocity will help the air get past some of the TB and intake restrictions better, improving the flow into the cylinders. Just taking a stab at a guess...
Now that tornado that you can buy, wow, what a great idea, spin the air into a tornado, can't go wrong there!
Second, the "stack" is acting like a venturi and should be increasing velocity.
Now I paused at what XTrooper said "A few guys tried these when they first came out and, if I remember correctly, lost 1-2 rwhp and gained about the same amount of torque." I'd like to know his rich friends or see those dyno results.
I can't see ANYONE who spend about fifty bucks on that part, pay the big bucks for a Dyno run to see what effect it had. That's a bit over the top for me to believe. So I gotta take it for what second hand information is worth.
..rickko..
Two requirements:
Material in = material out (conservation of mass)
P+.5(density)*V^2 is constant along the venturi (conservation of energy)
the pressure at the constricted end REDUCES, hence the velocity INCREASES to move the SAME amount of air molecules.
I still don't understand how this increases HP. I'll happily admit I'm wrong if someone can tell me how this increases HP.
Still not sure how the addition of a nozzle helps since atmospheric pressure is constant and the vacuum generated by the engine (hence the pressures on either side of the nozzle) are fixed.
oh well.
No matter how fast or faster you can get the air into the intake manifold, aren't the cylinder's going to suck in only so much air???
No more air can get in unless you force it or compress it in right??? Once the cylinder is full, it's full?? Is this correct??
Velocity stacks have been used on hotrods since the '50s to increase hp. Racing cars have used them. Old Indy cars used them. The list goes on and on, boat racers use 'em.
Its a cheap and easy installation mod. It definitely won't hurt your performance (unless you are one of XTroopers friends. I wish I could get one of them to send me theirs.). If you do notice an improvement what more could you ask for for fifty bucks. But if you don't notice anything then to quote you, "oh well."
fifty bucks is like pocket change when you own a vette anyway.
Fortunately you get to decide where its spent. Here's a couple quotes I pulled off the internet related to Velocity stacks in general.
"The performance advantages of velocity stacks and turbo bellmouths have been well known to race engineers and engine builders for decades."
"The rammed air affect of Velocity Stacks and Turbo Bellmouths have been shown to improve airflow into the induction system by around 19%"
But I don't care what they say because I know Bernoulli was correct.
..rickko..
..rickko..
..rickko..
If I'm reading your explanation correctly, the tapered intake vs. straight increases velocity of the air [we agree] and hence you are saying the mass flow rate increases, i.e. more air [this is the point I'm sticking on] as your buddy Bernoulli's
principal dictates that the pressure of the air changes to accomodate this increase in physical velocity in order to maintain the same mass flow. I guess I'm not asking or saying it right, so I'll let it go.
Velocity stacks (in general) obviously work as they would not be on every carbuerated racing engine around...so it's clearly me just not getting it.
.....No real way to measure 5HP on a dyno.
I did two dyno pulls with a very reputable group, (21st Muscle Cars) and the first dyno showed 296.8RWHP and 315.7RWT, and then 5 minutes later did another pull.....all variables the same, no changes to car or weather condition and the second dyno pull showed 308.6RWHP and 321.1RWT.......that's a big difference, and no changes in anything, just that the drivetrain and parts had heated up which made the difference.
Any tuner knows that dyno's are good to measure major HP changes and obviously tuning a car, all the little stuff under 8-10ishHP and less is not realiable stats. Tuners will all tell you the same thing......you can make a dyno tell you anything if you really want.
The stack is
Mabye a real tuner will chime in and set us all straight.
Same thing I was thinking. Also, as velocity increases, pressure decreases. I don't know if this has a noticable effect or not. Just thinking that FI cars with more (lots more) pressure makes more HP, I can't help thinking that less would somehow decrease HP. I guess that Heat transfer & Fluid Flow class wasn't useless after all.
That means, without the stack, the pressure the air is exerting on the sides of the throttle body (where you'd insert the stack) if it could be measured as it passes into the induction system would be higher than if you could measure it on the sidewall of the stack if it were inserted.
But that ISN'T the reason for buying a velocity stack. Its in the phenomena created by the stack; it increases the velocity of the air moving in/through the induction system (I hate to use this analogy but kind of like a the effect/principal of a turbo charger which crams air into the induction system).
Take a look at that link I suggested in my first post. You can design the stack any way you like and see the effect (the velocity curve) change based on how you shape it. Make it a straight pipe and check the blue velocity curve. Shape it like a venturi stack and note the change (increase) in velocity.
I don't have a clue as to the speed air is normally asperated into the engine but say its at the rate of 100 miles per hour. If the stack increases that 19% or 19 miles per hour, then you are ramming more air in over the same amount of time (ie. valve open) thus 'ramming' more into the cylinder (more to compress), etc. etc.
That's why it works and as Yellow01 said, "Velocity stacks (in general) obviously work as they would not be on every carbuerated racing engine around..."
What I don't know is, when DO THEY affect HP and torque? is it only at the highest RPM or is the effect consistent throughout the RPM range? IOWs, if you rarely push your car into the 4k+ RPM range is the $50 for the easily added on part worth it?
My opinion is, it sure won't hurt! Its cheap, and if it really kicks in only above 4k or 5k RPM then, cool; it'll be there waiting to shine when I want it too, like maybe the day you want to pass an 18-wheeler as quickly as you can because of oncoming traffic and you're running out of passing room.
..rickko..
PS. For the uninformed, dyno runs are expensive and something you don't generally spend your money on casually (ie. to check out a $50 part) unless you are expecting to see large differences between runs. And they aren't fun to watch when its your car on the dyno.
They'll make you cringe.
