27psi or 30psi ???
I run mine at 26 cold in the rear & 27 cold in the fronts.
the last set I ran around 32 and the center wore out before the rest .. i realized this and dropped the psi .. then it wore the rest of the tire out.
Just when I thougth my 350Z handled better...Man enough to admit my mistake and lesson learned.
In Ohio, land of extremem temp swings, my pressure will vary between 25 and 30 morning to mid afternoon. I usually get 4 "dings" in morning on my way to work. But by the time I'm leaving for home, they're perfect.
Although, I like the ride a bit better when the rears are over 30....33 ish is perfect for me.
The factories adjust for the temperature change as they warm up. Set them at 30 psi. Period. The factory recommendation is 30 PSI cold, which means just that; not 27.
However, it's all personal choice...some people like to run their tires a bit lower or higher.
If you leave them at 27# you may get a low press warning....
I'm going to lower them to about 28 - 29 cold, and whatever they rise to this summer, so be it.
30 psi is correct.
30 psi is correct.
although it is acceptable..
People spend thousands on tuning their car, yet they let the one thing that connects HP to the road ( the tires ) to a sticker that was designed to protect against product liability, not performance , gas mileage or tire longevity. Early on there were issues about customers putting 44 psi as stated on the sidewall and having liability issues. Thus the very generic 30 psi sticker on the door.
1 or two psi can add or subtract hundreds of tire miles, 1 to 3 miles per gallon. This is so important that road surface temps are monitored BY every racing institution on the planet. I can't believe all these people have no clue about setting tires in the winter at 30 and setting them in the summer at 30, and no one seems to think that there is no benefit by tuning the tires for your driving conditions..
30 cold could easily equate to 34/36 psi, which is way too high, causes a center high condition, less contact patch, poor traction, loss of performance and gas milage. THat sticker goes on every car made, whether its in a -25 degree winter Minisota or a 115 degree day in Texas where black top roads can reach 160F, and tires swell to 36/38 psi..
If you think these tires perform the same at 27 as they do a 37 psi, then your just throwing your money away modding your car.
43000 miles on my tires and 33 mpg speaks for itself.
Just noticed my pilots doing this at 30 psi cold and dropped a few pounds per tire. Glad i'm not the only one!
-Rich
