27psi or 30psi ???
Old Jun 18, 2005 | 05:35 PM
silverstreak01's Avatar
silverstreak01
Default 27psi or 30psi ???
I'm new to these factory Run Flat Tires. the book says keep at 30psi. OK, if you do that they seem to heat up 3 more degrees when you drive now your running 33psi which I've read from this form is too high. So the question would be, do you set them at 27psi and let them heat up to 30psi? If you have Run Flats what are you doing? Thanks for your input.
Old Jun 18, 2005 | 05:59 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I just read on here today to adjust seasonally so they're running hot at 30, makes sense to me........ you're right , set them cold around 27 or so.........
Old Jun 18, 2005 | 06:18 PM
AdamC5's Avatar
AdamC5
The recommendations for PSI by the tire companies are usually what is referred to as cold. That means if they recommend 30 PSI, that's what your tires should read when they are stone cold (what they read first thing in the morning, not having been driven on, etc). The companies don't expect you to do the math and compensate for driving.
The factory recommendation is 30 PSI cold, which means just that; not 27.
However, it's all personal choice...some people like to run their tires a bit lower or higher.
Old Jun 18, 2005 | 06:29 PM
azmusclecar's Avatar
azmusclecar
I say keep them at 30 year round COLD, as stated BEFORE you drive on them. Life is simple , why do we make it hard?
Old Jun 18, 2005 | 09:13 PM
Joe's Eray's Avatar
Joe's Eray
30-32PSI for my Kuhmos.
Old Jun 18, 2005 | 09:30 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
This must be tough.
Open door
read label
inflate tires!
30psi cold
Old Jun 18, 2005 | 10:42 PM
Mike94ZLT1's Avatar
Mike94ZLT1
WHOOPS! I put 40 in them, just like my BFG's on my SS. BRB, gotta go let some air out...
[edit] And who the hell would have thought that the tires on a Corvette would need different air pressure... thats ridiculous!
Old Jun 18, 2005 | 10:55 PM
fdxpilot's Avatar
fdxpilot
Don't know about your SS, but my 94Z says 32psi, with 35psi recommended for sustained high speed driving. My wife's PT Cruiser calles for 35psi. Almost all the cars I've ever owned had different pressure recommendations.
Old Jun 18, 2005 | 11:04 PM
vetterlatethannever's Avatar
vetterlatethannever
, not saying we're right though.....
Old Jun 18, 2005 | 11:06 PM
C5 4 ME's Avatar
C5 4 ME
30lbs cold here
Old Jun 18, 2005 | 11:14 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
30 psi cold. After they warm up they will read between 32-34 psi.
Old Jun 18, 2005 | 11:24 PM
Mike94ZLT1's Avatar
Mike94ZLT1
The tires say 44 psi max pressure on the side, I figured 40 was a safe number.
Old Jun 18, 2005 | 11:49 PM
Double Aught's Avatar
Double Aught
During my road trip to Tucson and Chandler, I was reading 35psi all around and my speed varied between 75-90.
Old Jun 18, 2005 | 11:51 PM
GrayC5's Avatar
GrayC5
The Tire Loading Label on the door shows recommendations for cold tire pressures and when they're hot. These recommendations worked well for my neighbor and appear to be working well for me thus far. My neighbor followed these recommendations very closely with his first set of GY run-flats and had over 44k miles on them with some spirited driving when he replaced them. They still had close to 4/32" of tread on them when he replaced them.
Tire Loading Label - 2002 Coupe:
Old Jun 18, 2005 | 11:54 PM
You set the tires at 30 psi when they are cold - yes they will warm up to about 33-34 psi when hot, but that is normal.
Old Jun 19, 2005 | 12:17 AM
1998 GTR's Avatar
1998 GTR
It's also a good idea to keep an eye on how the tires are wearing, especially if you ever use something other than the run flats. I have Michellin Pilot Sports and run 27lbs in front and 26lbs in back, but they are much wider than stock (275/35-18 fronts and 345/30-19 rears). When I bought the car it had 30lbs in the rear, and I didn't keep a close eye on the wear -- They wore out bald in the centers, but still had good tread on the edges. At 26/27 they wear very evenly. I'm sure I could have gotten a lot more miles out of them if I had kept an eye on how they were wearing.
Old Jun 19, 2005 | 10:51 AM
bekdad's Avatar
bekdad
The tire manufacturer's "maximum pressure" is the air pressure limit the tire can be used at. It has nothing to do with the pressure that the car manufacturer says is best for that particular car. As stated by others, 30 PSI cold is recommended.
Does it ride kind of hard at 40 PSI?
To 27psi or 30psi ???
Old Jun 19, 2005 | 10:54 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by ztheusa
This must be tough.
Open door
read label
inflate tires!
30psi cold
Old Jun 19, 2005 | 10:56 AM
azmusclecar
That sounds normal for our temps around Tucson, don't forget to wave to the 03 MSG Vert when we pass.
Old Jun 19, 2005 | 11:19 AM
3RD-INF's Avatar
3RD-INF
I just had the G/Y GS-D3 installed yesterday. Had them set at 29 cold. If this is too high or too low somebody needs to set me straight. That's the pressure I ran in my runflats. Gary
