What am I doing wrong?
Old Jun 22, 2005 | 11:59 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default What am I doing wrong?
I just recently moved and my driveway doesn't blend in smoothly with the street. It's design is like a backsward question mark (?). That's the best description I can come up with.
I can pull into the driveway and never scrape the spoiler, but when I back out of the driveway I scrape it everytime.
Am I doing something wrong or do I just have to live with it?
Any tips or suggestions would be appreciated.
Thanks,
Rock
Old Jun 22, 2005 | 12:01 PM
UT-Driven's Avatar
UT-Driven
Are you turning to the left or right as you back out over the threshold? If you exit on an angle, it should help.
UT-Driven
Old Jun 22, 2005 | 12:03 PM
Hot BluZ's Avatar
Hot BluZ
From: The problem with socialism is eventually the government runs out of other people's money
Sounds like you maybe entering at an angle and backing out straighter, pay attention to the angles your going in and out and see if this solves the problem.
Old Jun 22, 2005 | 12:19 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Old Jun 22, 2005 | 12:47 PM
rockrz's Avatar
rockrz
Yep....try to hit the transition at a 45 degree angle. Easier coming in than going out, but that's life. You could create a turnaround area and hit it going forward also.
Old Jun 22, 2005 | 05:32 PM
BigJoe's Avatar
BigJoe
I have the same problem and, yes, I scrape more backing out than driving in. I think in my case as I drive off the "lip" from the drive to the road the car settles a bit and that is what causes the scrape. Going in it bounces a bit and doesn't scrape. (I'm doing both of these very slowly, so the effect is very tiny but enough). Its done it in all 4 of my C5s and I have never had to replace the air dam, so it sounds worse than it is...
Old Jun 22, 2005 | 07:30 PM
Larry_Yerton's Avatar
Larry_Yerton
I found on my driveway backing out at an angle slowly makes it scrape worse. I now back out at an angle and at a moderate pace and it hardly scrapes at all.
Old Jun 22, 2005 | 07:34 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Your next mod! A&A Rocker Rails
Old Jun 22, 2005 | 09:00 PM
Try going on an angle. If that doesn't work, you may just have to live with it.
Old Jun 22, 2005 | 09:07 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
move
frame savers/rocker rails from a&a help out a lot.
Old Jun 22, 2005 | 09:14 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
Why are you so worried about the front air dam. you are not hurting the car
To solve all scraping you could put a lift kit on the car
Old Jun 23, 2005 | 01:45 AM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
If it is the black plastic air dam, don't worry about it. It is spring loaded and is designed to flex and re-center it self.
If you really can not live with it scraping like that, get some quickcrete and make it a smooth transition from the driveway to the street.
AZC5
To What am I doing wrong?
