Tire Iinflator
Old Jun 23, 2005 | 03:46 PM
Steve Zamcheck's Avatar
Steve Zamcheck
Default Tire Iinflator
The GM tire inflator, pump only, lists at $393.00. Will any over the counter inflator provide enough PSI, around 250 PSI, to be strong & fast. I just need a no frills small 12 VDC pump. Any special brand & where to buy, you folks suggest.
Steve
Old Jun 23, 2005 | 04:00 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
You only need 30 PSI why do you want one that is rated for 250 PSI?
Old Jun 23, 2005 | 04:18 PM
GOZ2FST's Avatar
GOZ2FST
Ummmm...yeah - 250psi is kinda extreme. I got one from Sears for around $20 -works fine.
The GM one maybe is for the Space Shuttle or something.....
Old Jun 23, 2005 | 04:22 PM
lickitydoo's Avatar
lickitydoo
If you blow real hard you might possibly be able to accomplish that, and its free.
Old Jun 23, 2005 | 04:52 PM
Shylor's Avatar
Shylor
The GM unit is junk and overpriced. You can get the same thing if you want, for less than $50. You might want to check out the Slime kit. They are coming out with an even smaller pump. http://www.slime.com/smartspairs/
Old Jun 23, 2005 | 08:51 PM
Steve Zamcheck
Default Inflator?? to SHYLOR
Thanks for the info. Never heard of SLIME. For those other replies to my question.The higher the PSI capacity the less the unit has to work to do the job and the faster it is done without extra heat effecting the unit.
Thank you for the help!
Steve
Old Jun 24, 2005 | 03:34 AM
Shylor's Avatar
Shylor
Slime has been around for years. It's just another form of spare tire in a can.
Old Jun 24, 2005 | 06:12 AM
ebubman's Avatar
ebubman
interesting. can you do the slime kit thing w/ emt tires or, given what i read here often, since most tire dealers don't want to fix emt tires, is it rather a moot point? just wondering. bub
Old Jun 24, 2005 | 11:14 AM
c5chris's Avatar
c5chris
Don't these fix-a-flat compounds ruin your pressure sensors?
The Z06s do not have run-flats/tire sensors. How do people who have tire sensors installed get around this expensive problem?
Old Jun 24, 2005 | 04:07 PM
Shylor's Avatar
Shylor
Yes they do ruin tire pressure sensors. But as a last resort I'd rather ruin a sensor than be stranded.
Those of us with sensors on Z06's use a vulcanizing tire plug kit, a small jack and also carry Slime or spare tire in a can. If I have time I would try to plug the tire. But if it were dark and raining, I'd use the Slime.
Old Jun 24, 2005 | 04:56 PM
Steve Zamcheck
Default Shylor........Inflator
I fond a good 250/psi capacity. 30/psi unit at WalMart $9.96 w. or w.o. gauge. Will give it a try. From Campbell Hausfeld.
Steve
To Tire Iinflator
