Column Lock Bypass
Old Jun 29, 2005 | 10:55 AM
COHMATT's Avatar
0COHMATT
Former Vendor
Default Column Lock Bypass
Steering column lock bypass kit for all 1997-2004 Corvettes
This bypass will eliminate the problem with the steering column locking up
The kit includes bypass box, harness and connector, instructions and everything you need to install
Also includes a 12 Volt adapter, which is necessary to disable the lock before installing the bypass box. The adapter is no longer needed after the bypass box has been installed.
Purchase now and avoid being stranded because you start your Corvette and have the steering column lock and can't turn the wheels
$49.95
to order Call Chris at 800-829-6434 or click here http://www.corvettesofhouston.com/im...lockbypass.jpg
Old Jun 29, 2005 | 11:27 AM
bozo4onion's Avatar
bozo4onion
Boy this is really old news, but dumba$$ me thought the friggin' thing had to stay plugged in all the time. Oh, well DUH and thanks.
Old Jun 29, 2005 | 11:31 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Good advice, especially for MN6 owners - even if you have had the recall done the locking system can still fail.
Old Jun 29, 2005 | 11:38 AM
Hot BluZ's Avatar
Hot BluZ
From: The problem with socialism is eventually the government runs out of other people's money
Got mine from COH couple weeks ago, installation was easy, less than 30 minutes, just with '04 did not need to turn on ignition, as described in the installation instructions, to unlock Column Lock as my accessory plug is hot. Like having the peace of mind from not worrying if I'll get stranded due to column lock.
Old Jun 29, 2005 | 01:57 PM
W.A.M.'s Avatar
W.A.M.
I just bought my C5 and been on this site for a little while and keep seeing this column lock mentioned.
Haven't done a search on it yet but can somebody give me a quick summary of the problem? Does it affect all years ?
Thanks.
Old Jun 29, 2005 | 02:03 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Thanks.
Here is some good reading on the subject:
http://forums.corvetteforum.com/show...483&forum_id=1
It affects automatics from 1997-2000
and all manuals.
If you have an auto take it to the dealer to have the recall done. If you have a manual buy the column lock bypass and install it, do not take it to the dealer because they do not fix the locking mechanism problem. end of story
Old Jun 29, 2005 | 04:38 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
got mine from COH.. works great!
Old Jun 29, 2005 | 06:28 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Get 'Er Done or you may have to get 'er hauled!
Old Jun 29, 2005 | 06:47 PM
DC-STRO's Avatar
DC-STRO
From: After reading this thread, I gotta tell ya... you're an ass. .
St. Jude Donor '05-'06-'07-'08-'09-'10-11-'12-'13
OK...Help me out..I just got a recall notice today from Chevrolet.
I bought my Vette last Sept. I have never had a problem, or did the previous owner...It's a 98 A4 with 40K on it.
What does the dealer do to fix the problem..?
Should I tell the Dealer to get bent, and get the by-pass kit..?
Old Jun 29, 2005 | 08:48 PM
Cajun99's Avatar
Cajun99
With all respect...PLEASE take the time to do a search and get informed
This issue is the most discussed on this Forum and has been for years.
It would be nice if more folks showed a little initiative and did a little research on their own
The CLB information is all over this Forum...all you have to do is read it.
To Column Lock Bypass
