Adding HUD?
Old Jun 30, 2005 | 08:17 AM
JGreen's Avatar
JGreen
Default Adding HUD?
Can you install HUD into a 2001 Zo6? Has anyone done this, and how tough/expensive is it?
Old Jun 30, 2005 | 08:26 AM
AFVETTE's Avatar
AFVETTE
Taking the dash apart is the hardest part for first time DIY'er's. But once you have done it, you'll see how easy it is.
Fred Bean's sells all the parts necessary for about $260 plus shipping, of course that doesn't include the special HUD windshield. But from what I have read, the HUD displays very nicely on a standard windshield. Here's his link scroll down and look for "Genuine GM HUD Setup" parts and prices - http://forums.corvetteforum.com/show...53&forum_id=53
Tom
Old Jun 30, 2005 | 08:31 AM
SSTOZ06's Avatar
SSTOZ06
Default Hud
I Installed One By Myself On My 01 Zo6 And For The Most Part It Was Easy Compared To Most Dash Removals. I Got The Parts From The Forum And Ebay And A Local Gm Dealer
Old Jun 30, 2005 | 09:16 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Nice write-up on it here...http://forums.corvetteforum.com/show...0&forum_id=103
and here...http://joshker99.home.comcast.net/hudinstall2.htm
Old Jun 30, 2005 | 09:32 AM
michach1's Avatar
michach1
I did this mod on my 04 coupe.
For others who are considering this and have an 04 (I'm not sure about earlier years), you do not need to drill the holes described by Josh. There are already two bolts in place. Just gets some nuts, slide the projector on and tighten the nuts. If anyone needs the nut sizes, I can look them up for you.
This mod is a lot easier than most of you might think.
Old Jun 30, 2005 | 12:00 PM
BudgetPlan1
So I won't need the right angle dremel? Or need to drill any holes? (have 2004 coupe) That would be
Old Jun 30, 2005 | 12:51 PM
It certainly can be done. This is one great mod to do if your car did not come with the HUD.
Old Jun 30, 2005 | 01:13 PM
JGreen's Avatar
JGreen
Just so I am clear on this...I have a 2001 Zo6 (obviously without HUD) that I want to do the install in. From the description below, my dash should be HUD enabled, correct? I should only need the projector, dash bezel, switch and 11 Pin from the switch to cluster, right? I am not going to do this mod until I put her up for the winter, but I want to have everything staged so i am ready.
"There are 2 different HUD install scenario's.
97, 98, or early 99 C5's without the HUD enabled cluster - You will need to get a late 99+ Cluster. The only way to tell whether you have the HUD enabled cluster is to remove the one you have and look for the white connector in the very back. If it doesn't already have the HUD Switch you will have to install one and find a 11 pin harness (I have harnesses that are ready to plug and play for $45 plus shipping, email me for details) If you need a HUD enabled cluster you will have to have it programmed with your existing mileage. I've heard ~$50 to do this, but contact your dealer. You will have to drill 3 holes to mount the projector, 2 in the plastic dash support, 1 in the aluminum column support. If you use a late 99-04 cluster you will also have to move the airbag warning light located next to the fuel gauge to the location on the Tach or else the light will remain lit al the time.
Late 99-04 C5's with a HUD enabled cluster - You will need the projector, dash bezel, switch and 11 Pin from the switch to cluster. You will have to drill only 2 holes in the plastic dash support, the third is already notched out."
Old Jun 30, 2005 | 02:31 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I just got done with this mod so hopefully I can provide some insight.
You are correct on your parts list. You should already have a HUD enabled cluster.
There are two holes that need to be drilled in the plastic under the dash pad for the cluster to mount to. I did not have an angle attachment but was able to use my 'rotozip' type tool to make the holes. They are not perfect but are good enough for the rubber anchor grommits to fit and tighten up. there should already e a notch out of the plastic for the third mounting point.
The HUD bezel was a mystery to me. I did not see how it could go on flush without cutting the dash pad WAY back to the edge of the bezel. I ended up cutting down some of the material on the underneath of the bezel and used some self tapping screws to attach it to the dash pad rather than the JB Weld that is suggested. It fits flush on the left side but I'm still not happy with the right side so I may end up removing it again to trim more off.
I was not able to get the screw back in which is on the left side of the defroster vent. The pad doesn't sit flush to the plastic there. It seems like the projector is keeping the dash pad pushed up just a bit there. You can't see anything from the outside but I know it's not quite right. I'm curious if anyone else has seen this or if it's just me.
Be sure to test out your projector prior to buttoning up. I tested mine but did not notice at the time that my display is just a scosh tilted to the right. I can fix this if/when I take the dash pad off to fix the bezel but honestly, neither are that bad to make me want to take it all apart again.
For the 11 pin connector I was able to dig through my PC parts drawer and find what looked like a cable to a sound card. It was 4 pins wide and fit on the switch right next to the stock 7 pin connector. If you're not this frugal/industrious you can get one from Josh.
The instructions say to remove the glove box and it's kind of a PITA. I think it's just to get to four bolts up under the dash and, if so, these can be reached without taking out the glove box.
For $260 this is well worth the effort to get the HUD!
HTH
Old Jun 30, 2005 | 04:42 PM
michach1's Avatar
michach1
That is correct. The nuts were metric. I don't recall the size exactly. I was a dumbass and had to go back into the hardware store several times to get the right size. I kept looking at English size nuts. Who would have thought that America's finest sports car was all metric?
On a related topic, before I learned of the bolts already being in the car, I went out looking for well nuts. Home Depot does not carry them. Lowes did but had a very limited supply.
Also, if you do have to drive your car with the dash out (to go to the hardware store or something), beware that you will not have turn signals. If the hazard switch is disconnected, you will not have use of your signals either. FYI.
Old Jun 30, 2005 | 06:00 PM
jim2527's Avatar
jim2527
I have all the parts sitting here to do mine. Its nice to know I dont have to drill my '04. As far as ordering your harness from Josh......He's a great guy to deal with. I pay-palled him the money and it showed up in a few days.
Old Jun 30, 2005 | 06:35 PM
98vert6spd's Avatar
98vert6spd
i didnt even drill or secure the fron of my hud unit when i put it in my 98
i drilled the hole for the back
and put it in
the dashpad presses it firmly in place
its not going anywhere
no need to drill those other holes
Old Jun 30, 2005 | 06:46 PM
GrayC5's Avatar
GrayC5
...and yet another from C5 Tech Tips:
Installing a HUD
Old Jun 30, 2005 | 07:40 PM
LoneStarFRC's Avatar
LoneStarFRC
and put it in
I agree with the no need for drilling. Use some 3M double sided tape (the gray stuff with the red backing) instead of drilling the two front holes. It will hold the projector just fine. Just install the left rear bolt like stock since it's so easy to get to.
Old Jun 30, 2005 | 09:58 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
I also have a HUD installed in my 2001 Z06. Josh ( Pacethis ) installed mine, and did a fabulous job.
Old Jul 16, 2005 | 09:40 AM
jim2527's Avatar
jim2527
Does anyone know the nut size?
Thanks, Jim
Old Jul 16, 2005 | 02:49 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
This will be my next mod.
To Adding HUD?
