How can I remove wheels locks without key ???
Old Jun 30, 2005 | 11:04 PM
ROYZC5's Avatar
ROYZC5
Default How can I remove wheels locks without key ???
I just jacked up car to paint calipers before I have new wheels installed next week. I found wheel locks on my standard 98 wheels, I searched entire car, no key. How can I get lugs off without key ???? Any help would be appreciated .........
Old Jun 30, 2005 | 11:11 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I believe what thieves do is to jam a socket onto them. It may cost you a socket ot two but it seems to work for them. The most common places for the key to be is in the center console or in the rear compartment.
Old Jun 30, 2005 | 11:12 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
I believe what thieves do is to jam a socket onto them. It may cost you a socket or two but it seems to work for them. The most common places for the key to be is in the center console or in the rear compartment.
Old Jun 30, 2005 | 11:16 PM
JEEP/C5's Avatar
JEEP/C5
I had a similar problem with my 01. I bought it used last summer and a week later wanted to check the brakes. When I took the plastic caps off I found they had lug nut locks on it. I search the car for the key but I could not find any. They looked like factory type locks. I called the previous owner and he said he did not have a key. So I called 3 tire shops and my local GM dealer. None of the had an easy solution. GM wanted to charge like $65 per hour until they got them off. So I looked at it again and took assortment of sockets. I found a metric one that would slide over it and fit really tight. I hit it with a hammer two or three times to really get it on tight and then used my breaker bar on it. I had all 4 off in 15 or 20 min with zero damage to the rims. Give this a try. My 01 factory rims had enough room to use a socket over it, check yours so you don’t damage the rim with the oversized socket. Good luck.
Old Jun 30, 2005 | 11:20 PM
hokievette03's Avatar
hokievette03
St. Jude Donor '05-'06
Try the glovebox where most small factory accesories are located
Old Jun 30, 2005 | 11:27 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
The storage area for the key is in the left storage compartment in the
rear of the car. When you removed the lid, there is a nitch next to the
compartment where the key is supposed to be stored.
Old Jul 1, 2005 | 12:00 AM
yellowhammer1023's Avatar
yellowhammer1023
That is where I found mine. It was in a small back pouch.
Old Jul 1, 2005 | 12:07 AM
NSTG8R's Avatar
NSTG8R
not on the c5 ...
as mentioned there is a little (notch?) in the rear of the vehicle in the trunk (under the carpet?) for the key.
Old Jul 1, 2005 | 01:01 AM
TexasMadMan's Avatar
TexasMadMan
I'm glad someone asked about this. I've been meaning to address this issue.
I've got an 02 vert. Should I expect to find a lock on my wheels when I take the nut caps off? I have looked all over the car including the left well in the rear and can't even find the "pocket" you are talking about, even with the carpet pulled out. I'm sure my car has the original tires on it, so it's possible the lock would never have been used.
Do 02 verts come from the factory with wheel locks?
Old Jul 1, 2005 | 01:08 AM
rickko's Avatar
rickko
Originally Posted by JEEP/C5
.... GM wanted to charge like $65 per hour until they got them off...
I watched 'em take locks off at Costco once while waiting for new tires. The guy pounded a socket onto the lock then connected the impact wrench to the socket and spun the lock right off! Looked too easy!
..rickko..
Old Jul 1, 2005 | 01:19 AM
BickyDhadwal's Avatar
BickyDhadwal
try your trunk compartments...good luck
Old Jul 1, 2005 | 01:28 AM
3RD-INF's Avatar
3RD-INF
Mine came from the factory. They were on so tight that I twisted the key and broke it. Ended up chiseling the darn things. Once the locks had some good size burs, I drove an oversize socket onto the lock and used a half inch impact and backed them right off.
Old Jul 1, 2005 | 01:31 AM
Cajun99's Avatar
Cajun99
The "pocket" is located on the top leading edge of the divider between the left and center wells. You'll have to pull up or reach under the carpet to get to it.
Old Jul 1, 2005 | 01:34 AM
exukboy's Avatar
exukboy
I had same prob with my old C4. Orig factory locking nuts but no key.
I found a socket that slid on nice and snug. Then cut up some steel nails and slid then into the grooves on the lock nut then slid the socket over them and after a bit of adjustment all 4 came off with no trouble.
The pieces of steel nail take up the slack for when you slide the socket over. Just be sure to cut them to a suitable length.
Old Jul 1, 2005 | 02:32 AM
TexasMadMan
cajun99:
Thanks for the help. The factory must not want anyone to find that hiding place. I found it with your help, BUT someone must have taken the key out. After pulling up all the carpet in the back, I was very surprised to find 3 rounds of automatic handgun ammo that was hidden under the carpet. That might have proven interesting in a rear end crash.
The key ain't there. For grins I'm going to look under the seats, but it looks like I will have to do as others have done.
After reading all of the posts above, I have to wonder how all of these keys could have been lost or thrown away. Is it possible the factory is having the last laugh?
Old Jul 1, 2005 | 02:36 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I accidently put my key in storage and needed to take my wheels off. I took it to SEARS and the service manage had a socket designed to remove the "GORILLA" locks I had on my 2000. They charged me $10 a wheel (one lock on each wheel) and told me they would not be responsible for damages. Well, I was nervous, but went ahead and they took the locks out of each wheel and not a scratch! I tried jamming a smaller socket on the lock and torq wrenching it out, but that became cumbersome, with no results, so I wanted to ask folks that deal with this more often than I.
SEARS, they took care of my problem and my car.
Mcah
Old Jul 1, 2005 | 02:53 AM
TexasMadMan
Last question (I hope).
Is everyone replacing the locks with new ones or just using a regular lug nut?
To How can I remove wheels locks without key ???
Old Jul 1, 2005 | 07:11 AM
Good luck getting them off. I had a dealer take mine off on an older car when the key to the locks stripped out. But, if it ever happened again, I would be trying the "hammer the socket on the lug" routine.
Old Jul 1, 2005 | 07:16 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
If you can remove them with sockets and a little effort.....why would you want them on?
Old Jul 1, 2005 | 07:20 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
This is a good question that I have also thought about...There are always odds but to get your wheels is a thief going to assume we have locks and just bypass a vette? If they would REALLY want the wheels and you had locks, seems like they could do some real damage getting them.. Mmm, I dunno............
