How can I remove wheels locks without key ???
Old Jul 1, 2005 | 07:37 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
There is a socket that you can buy that has cutting threads built into it. Usually works with an air gun, but may work with a rachet. Yoy tap it on and turn them off really works pretty good. I believe Sears (Craftsman) has them.
Old Jul 1, 2005 | 08:29 AM
Cherry2000's Avatar
Cherry2000
I agree with several of the posters on jamming a smaller socket onto the lug. I was at a remote autocross and had a flat in a previous C4. Since I had recently had new tires installed, I found that NTB had kept my lug key. One of the member of my club hammered a socket onto the lug and we were able to remove it. There was no damage but easily could have been.
Old Jul 1, 2005 | 10:17 AM
ROYZC5's Avatar
ROYZC5
Thanks for all the help. I found the spot that is supposed to have the key, no luck, I am going to try and find that socket that goes over and bites onto the wheel lock .............
Old Jul 1, 2005 | 10:26 AM
DeeGee's Avatar
DeeGee
Good thread.
Finally found the spot where the key is supposed to be. No key. But then again, no locking wheel nuts.
Are they supposed to be standard or are they an option?
Old Jul 1, 2005 | 10:47 AM
Cart99's Avatar
Cart99
I had the same problem with my Camaro -- misplaced the socket.
I was able to buy a new socket from the dealer. They had a kit that determined the right socket for your particular car, and then just bought the correct one from the parts department. A little pricey, but at least you have the key for the next time.
Old Jul 1, 2005 | 11:30 AM
LB04CE's Avatar
LB04CE
04s didn't come with the locks did they?
Old Jul 1, 2005 | 11:37 AM
cadams's Avatar
cadams
Originally Posted by JDs00PewterCoupe
Good luck getting them off. I had a dealer take mine off on an older car when the key to the locks stripped out. But, if it ever happened again, I would be trying the "hammer the socket on the lug" routine.
thats what i did when my key got stripped. find a trusting friend to hold the tire iron and bang it on with a sledge hammer. then toss the tire iron away once the nut is off.
also, don't try to torque it off in one sharp pop. Put steady even pressure on the iron, and wait patiently for it to start moving, and go slowly; other wise the tire iron may pop off.
Old Jul 1, 2005 | 02:18 PM
ROYZC5's Avatar
ROYZC5
Well I went to local tire dealer and they removed all 4 locks with a socket that has a left handed thread that threads itself on and removes locks. Paint now drying on calipers, can't wait to see finished results............ once again thanks for forum help.........
Old Jul 1, 2005 | 04:34 PM
TexasMadMan's Avatar
TexasMadMan
Glad things worked out for you. Mind if I keep the thread going a little longer?
Having just returned form the Chevy dealer I bought the car used from, it was determined the locks on my wheels are not factory locks. The "keying" is on the inside of the lock and not on the outside like factory locks.
Is that the type you had? Will I run into more problems trying to remove these VS the factory locks.
I hate the thought of traveling through small towns without having some way to get the wheels off the car.
Old Jul 1, 2005 | 08:33 PM
Charlie from Cherry Hill's Avatar
Default Wheel Locks
Back in 2001, shortly after I bought my '99 FRC I needed to take off the wheels and found the wrong lug nut key came with the car. I called the guy who sold me the car. He said he'd look in his other Vettes and call back. I didn't hear from him and ended up taking it to a Chevy dealer that had a kit to fit all the locks. I thought about getting a replacement key, but then threw out the lug locks and the wrong key. Even though I've since gone over to Ronal wheels, I still don't want locks on my wheels. In my opinion they're just a waste of time. Oh yeah, I'm still waiting for the original owner to call me with the correct key.
Old Jul 1, 2005 | 09:40 PM
MagRedSkull's Avatar
MagRedSkull
This can be used to remove the locks or stuck lug nuts:
http://www.autobarn.net/emlugnutrem.html
BTW, I don't use locking lug nuts. That way I don't have to worry about losing the key or breaking the key.
Old Jul 1, 2005 | 10:25 PM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
Mine came in the trunk on my '02 vert. They were in a sealed package with the key. I put them on myself.
Old Jul 2, 2005 | 09:06 PM
  #33
ROYZC5's Avatar
ROYZC5
My locks were the ones with the keying on the inside, this socket fits over the outside and turns lock off after it bites into the metal. I don't think I will install locks when I get my new c6 wheels later this week.
Old Jul 10, 2005 | 10:36 PM
  #34
C5 Z16's Avatar
C5 Z16
Default Sears Bolt Out
This tool worked for me. Sears Bolt Out. Tapped on with a hammer then the cutting flutes gripped into the metal and turned the locks right off. I had to use one size smaller than you would think to let the cutters get a grip.
http://www.sears.com/sr/javasr/produ...id=00952166000
http://www.sears.com/sr/javasr/produ...id=00952161000
