Question, installing Bilsteins
Old Jul 2, 2005 | 01:27 AM
Rex99Coupe's Avatar
Rex99Coupe
Default Question, installing Bilsteins
Installing Z06 springs, sway bars and Bilsteins. Installed the front Bilsteins tonight after the spring with the four a-arm bolts removed, used the hardware supplied with shocks. Can't get threads to show above upper nut, upper insulator is compressed. Does this sound correct?
Old Jul 2, 2005 | 05:35 AM
FiberglassFan's Avatar
FiberglassFan
In a word, no. Sounds like you might have the upper shroud above the circlip..It need to go below the circlip. As you go up from the bottom, on the shaft, first will be the rubber bumper, the shroud, circlip, lower washer, rubber, chassis, rubber, upper washer, nut. Does this sound familiar?
Old Jul 2, 2005 | 05:40 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
That is normal. I had the Devil's own time getting my top bolts started. Eventually used a Vice Grip to compress the 2 top rubber isolators.
A second pair of hands would have made the job easy, but I installed them alone
Old Jul 2, 2005 | 08:39 AM
Rex99Coupe's Avatar
Rex99Coupe
"In a word, no. Sounds like you might have the upper shroud above the circlip..It need to go below the circlip. As you go up from the bottom, on the shaft, first will be the rubber bumper, the shroud, circlip, lower washer, rubber, chassis, rubber, upper washer, nut. Does this sound familiar?
Yesterday 10:27 PM"
Got it, Thanks!
"That is normal. I had the Devil's own time getting my top bolts started. Eventually used a Vice Grip to compress the 2 top rubber isolators.
A second pair of hands would have made the job easy, but I installed them alone " I will try the vise grips. Thanks!
Old Jul 2, 2005 | 10:36 AM
FLL-Mike's Avatar
FLL-Mike
Thinking about doing the same. Let me know if the $$$ to mod is worth it
To Question, installing Bilsteins
