Hey everybody. My dad finally decided on a new exhaust. He is going to pick up a borla stinger system. I was wondering how hard it would be to install ourselves? thanks.
If you lived in my area I say come over put it on the lift be done in under a hour. Check with members in your area maybe you will find someone. Good luck and be safe.
did mine on a lift...with a friend...TAKE OFF THE SWAY BAR...then its super easy...took about 10 minutes to bolt on the new system and about an hour and a half to get the old one off becuase we didn't think of taking the sway bar off for the first hour....40 mins is all i need if i were to do it again
I put the Corsa Indy on mine yesterday. No lift, just a jack and a piece of 4x4 to get it high enough to roll the originals out. Once I rolled it out, I lowered it and did it all in about 2 hours.
I still do not have them even. My right side extends out a little more. Not sure which adjustment to make for that.
Just one tip no one has mentioned. If you've got an A4 remove or at least loosen the heat shield on the passenger side. You'll see it when you get under there. If you don't you'll wrestle it all day long and not get the old one out. This whole step in unnecessary if you have an MN6 or don't mind cutting the old system. Good Luck!
PS - If you use a jack get it up as high as you can and then take it a couple more inches. You'll think it's standing on it's nose. Also use stands!!!
