Ok sports fans. I have been looking for a 2003, Speedway white, convertible, 6 speed, tan interior (I would take the red if I must), Options: 1SB,F-55,G92, MN-6, and Z-51. NOW..the test..how many do you think were made in that configuration in 2003....? I have no idea how to figure it out..But, I know there is someone out there in Corvette land that can tell me in 10 minutes. Thanks for helping me out on this one. 55 Merc. HINT: there were only 679 total white ones made in 03'.
None. Can't get both F55 and Z51, it is either or. And you can't get the G92 performance axle with the 6M.
Ron C is correct. Also, GM does not publish final production numbers in the format you are wanting. They only publish the final numbers for each individual option (RPO) by type car (coupe, vert, and FRC/Z06) and the total for that option. They do not publish productions numbers for other combination of options.
Below, are the final production numbers for model year 2003. The RPO column shows many (if not most) of the options that are incompatible and cannot be ordered together (i.e., F55 & Z51, G92 & MN6, etc.) along with others that must be ordered together. Using extrapolation and the final production numbers below, you may be able to come up with some fairly close numbers for the combinations in which you are interested.
