Absolutely do not take it in for the recall after you install the CLB. All they will do is reprogram your computer so it will shut down your fuel supply if the gremlins ever take over. I, too, have an '02 and I installed the CLB myself and later when I had to take mine in for warranty repair of the leaking rear axle they asked me about doing the CL recall and I simply refused it. They asked me to sign the warranty invoice showing that I had refused the recall. It was simple to refuse!
Sanford
I am scheduled to have the recall work done tomorrow. I ordered the clb kit on yesterday. i hope i am doing this right. any suggestions
Okay guys the deed is now done...
...In fact while I was installed the CLB...I replaced the plastic bezel or shroud surrounding the ignition switch...
and I replaced the passenger side carpet vent...
Investigated problem with turn signals and found the sequential turn signal the problem...
I have an extended warranty but I was not about to get stranded for some simple preventive work I could do. Also for us Manual cars, even if GM paid for the tow, the fix would not prevent wheel from locking again.
