Could someone explain the differences in handling packages.
What is the difference between that package (I think it's an F45??) and the Z51 package and how do those packages compare to the mods you guys are doing by adding the Z06 swaybars and bilstein shocks.
Thanks in advance,
Mark
You have the Select Ride package or FE2 <edit>
It is a step up from base - FE1
Z51 or FE3 is a step above both select ride and base
Z06 or FE4 is the ultimate in factory options.
The Z51 front spring and the Z06 front spring are the same part.
Beyond that - there are Bilstein Sports shocks, VBP springs, Hotchkis sways, GM T1 racing sways, QA adjustable shocks, coilovers from Doug Rippie and LGM.....
A good compromise between handling, comfort and cost is Z06 springs, Bilstein Sports shocks and Z06 sways (with Z06 end links). It won't break the bank and the car will handle extremely well.
I'm ultimately going with the DRM coilovers and DRM T1 sways for max handling and adjustability. I need to get Grond in da weedz.
Stephen
Z51 or FE3 is a step above both magnetic ride and base
Beyond that - there is VBP springs, Bilstein Sports shocks, QA adjustable shocks, coilovers from Doug Rippie and LGM
Moderator???
Moderator???
The Z51 option included stiffer springs, shocks, and larger swaybars for more performance-oriented handling, with some degradation in ride quality.
You can certainly beef up the swaybars with the F45 pkg.
In order to switch shocks, you'll need to either have the F45 option programmed out of your computer (Tech-2 job), or use shock simulator modules (expensive).
EG - Magnetic ride wasn't introduced until 2003, that is the F55 option, although similar, the F55 is a bit more advanced than the F45 select ride was.
Is there a big difference between the FE2 package and the F45 package? I could have sworn my option code said F45 but apparently not.
Thanks,
Mark
Thanks,
Mark
F45 Selective Real Time Damping
F55 Magnetic Selective Ride Control (Replaced the F45 in model year 2003)
FE1 Base Suspension
FE3 Sport Suspension (Included with Z51)
FE4 Suspension System, Z06
Z51 technically is the RPO number for the Performance Handling Package which consists of the FE3 Sport Suspension and a power steering cooler.
You can find a little more on the C5 suspensions at the following link (As Y2Kvert4me mentioned above, the sways bar sizes and spring rates for the F45 are the same as for the FE1 base suspension.):
http://www.jakelatham.com/c5/misc/faq.shtml#2-1
2003-2004 Corvette Suspension Comparison
Thanks Gray,
One question though, where does the F45 fall into as far as comparison to the other suspension options?
Is the F45 worth upgrading with different sway bars or are they pretty decent?
I appreciate everyone's time and answers.
Thanks,
Mark
definately upgrade the sway bars.I went with hotchkiss( which is a little heavier that the zo6 sways,but quite a bit more expensive!)I suggest z06 bars,best bang for the buck..and simple to install
Springs are a little more involved to put in,at least the front one is..
I suggest upgrading the bars,and see how it feels to you.It made a HUGE difference in mine with the base(fe1) suspension,much tighter in cornering..less body roll
Springs later,...even shocks if you wanna go that far..
Thanks,
Mark
Several people here in the past have reported on improved handling after upgrading their F45 suspension with either the FE3 (Z51) or FE4 (Z06) sways/spring. However, I can't speak to this.
We ordered our car with the Z51 package and love it. I have never driven a car with the F45 suspension, but personally I think the Z51's (FE3) handling is much improved over the FE1 Base Suspension. The Z51 really comes into its own in the twisties and turnies and I love it for it's flat roll response. The Z51's ride is somewhat firmer, but definitely not what I would consider harsh. My wife and I make several road trip of 1K miles or more each year and we have been very pleased with the ride of our car.
Hope this help and good luck with yours.
Joe,
Thanks man, that's a good happy medium for me. All of my end links need replacing anyways so that'll be a good reason to switch over to the Z06 stuff...
I appreciate your advice.
Very helpful, as I said to Joe, definitely a happy medium. The car is a daily driver and I don't go to the track but I love to exercise her once in a while...
I appreciate everyone's help. Thanks all....
Mark
Sway bars, end lincks, springs, shocks, negitive camber concentrics, A-arms with poly bushings.
great for high speed cornering, but for the street use, rocks would be softer on bumpy roads.
Blue is GM T1 front, black is 2003 Z51 / ZO6 front
Blue is GM T1, black is Z51
I love this site BTW!
Congrats and welcome. You'll love this site. Very informative, very helpful and very addicting.
Mark
