I need help! =[
Old Jul 5, 2005 | 01:20 PM
Sean99SS's Avatar
Sean99SS
Default I need help! =[
I washed my car yesterday and and to drain the water out of the drive side mirror I pushed it in and left it pushed in for awhile. I went back out to the car later and the mirror is so loose that it won't lock in to place and just swivles back and forth. How do I tighten this back up?
Old Jul 5, 2005 | 01:48 PM
pewterwest99's Avatar
pewterwest99
Sorry to hear that.. I don't have an answer for you , but here's a
TTT
Old Jul 5, 2005 | 02:19 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
From other posts I have seen you will either need to take it apart to fix a broken mechanism inside, or find a replacement one that isn't broken. And if I am correct, to repair it you have to remove it from the door. You may try searching the C5 sections to find more posts on this problem.
A word of warning to others - do not fold the mirror in, it can break like this.
Old Jul 5, 2005 | 02:26 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Found this post for you
Old Jul 5, 2005 | 02:41 PM
MadRick's Avatar
MadRick
Default Pushing the mirror in did not cause the problem...
Pushing the mirror in did not cause the problem....on my 97 the mirror just popped out while parked in my garage....It is just a defective part on all 97's and some early 98's...Look at the post above....Ed from Ohio did a great job at fixing mine....And it was a fast turn around.
Hope this helps
To I need help! =[
