C5 Exaust Weld Failure
Old Jul 6, 2005 | 07:06 PM
hot-toy's Avatar
hot-toy
Default C5 Exaust Weld Failure
I had the welds on the muffler pipes fail at the flange on my 25,ooo mile 1998. The welds broke loose all the way around the flange. Welds didn't penetrate the pot metal flange. Has anyone else seen this failure?
Old Jul 6, 2005 | 07:16 PM
Patches's Avatar
Patches
Pretty common. Have an exhaust shop reweld and you'll be good to go.
Old Jul 6, 2005 | 07:17 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Old Jul 6, 2005 | 07:42 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
The drivers side came apart at the track a few months ago
Mine is a 99, good luck with the fix.
Old Jul 6, 2005 | 09:37 PM
Z0SLIK's Avatar
Z0SLIK
Was that before or after the 360's at 90 mph. And yes I said 360's.
Old Jul 6, 2005 | 09:41 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
The best cure is to put a cat back system on.
Old Jul 6, 2005 | 09:43 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Old Jul 6, 2005 | 09:46 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
That is not a cure at all, it's the flange on the mid pipe which breaks, i've broken both sides...last time it happened i had a local shop charge me 20.00 for fixing it.
Chris
Old Jul 6, 2005 | 09:47 PM
IM QUIKR's Avatar
IM QUIKR
Been there done that. Good time for the Cat-back and X-pipe Mod.
Old Jul 6, 2005 | 10:10 PM
T's's Avatar
T's
After..... Who new
Old Jul 7, 2005 | 01:07 AM
Deputy's Avatar
Deputy
Both pipes broke before 7,000 mi. on my '99. No weld penetration. Service manager (Fox-Rochester) claimed he never heard of this happening before. Then he threatened to charge me for repairs and denied me a loaner car.And when I picked it up, someone put extra miles on the odometer, it had a bend exhaust tip and a thick layer of dust on it. And they wonder why we don't come back.
Old Jul 7, 2005 | 01:35 AM
GrayC5's Avatar
GrayC5
My neighbor had the same thing happen on his '99 vert.
Old Jul 7, 2005 | 05:44 AM
BiggieBoy's Avatar
BiggieBoy
And I thought bad s*** only happens to me. This just happen to my 18k mile '98 a week ago. The driver side weld let go, taking off the mid pipe flange. Talk about noise....However, this "problem" gave me an excuse to buy a Bassani X pipe for my car.
I have a ? tho--I have to drive my car about 3-4 miles to the installer's location. Will the hot exhaust gasses/heat etc., coming out of the mid pipe cause any problems to the underside of my car???? Any advice will be appreciated...Thanks....
Old Jul 7, 2005 | 06:38 AM
Haven't seen any posts on this in a while, but yes, there have been many cases of the welds failing. A good muffler shop should be able to reweld the flange back on the pipe.
Old Jul 7, 2005 | 06:46 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Like some others...been there, done that, got the weld at a muffler shop...
Old Jul 7, 2005 | 11:26 AM
Ketch2631's Avatar
Ketch2631
I had the same thing happen four times. I would weld the flange back and it would last about 10,000 miles then break again. The last time it happened I just went out and bought a Corsa X pipe and haven't had a problem since.
Old Jul 7, 2005 | 01:03 PM
scoaman's Avatar
scoaman
My 99 vert broke and dealer replaced under warranty, on the 04 I changed the pipe before I put 10 miles on car.
To C5 Exaust Weld Failure
Old Jul 11, 2005 | 05:43 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
This happened to a neighbor of mine with his 99. The stealer, oops I mean dealer wanted $1700.00 CDN for a whole new exhaust system. He told them to pound salt and got it welded for $20 at a friends shop.
Old Jul 11, 2005 | 05:58 PM
SLPRC5's Avatar
SLPRC5
hi-flo cats and X-pipe only way to go
Old Jul 11, 2005 | 05:59 PM
OOBlackconvert's Avatar
OOBlackconvert
