[Z06] Engine Longevity
Old Jul 10, 2005 | 05:57 PM
EyesOnly's Avatar
EyesOnly
Cruising
Default Engine Longevity
Greetings,
I'm thinking strongly about buying a C5 Z06, but have always owned japanese cars, so I have no idea about the life of an engine. I know a Lexus doesn't start looking 'used' until about 100k miles, and most engines last between 200k-300k.
Since the Z06 is so high-performance, does this decrease the life of the car/engine? Any input?
Thanks,
Jason
Old Jul 10, 2005 | 06:36 PM
Chuck Harmon's Avatar
Chuck Harmon
The more power an engine generates, the faster it will wear out. Aircraft engines base their overhaul periods by estimates of engine load. The good thing is that even a Corvette driven modestly hard spends a very, very small fraction of its time under full throttle. The other strong point is that if highway driven, the engine is only turning about half as many revs as the C3 Vettes did. The several C3's that I owned also went well over 100,000 miles without problems, so I would expect my 2002 ZO6 to go way over 100K without problems. It has over 65,000 miles now without any issues or oil consumption problems.
This is my 5th Vette and they have all given me long trouble free miles. I think you can feel confident as long as you take reasonably good care (check and change the oil for example) of the car and don't drive like an idiot.
Chuck
Old Jul 10, 2005 | 06:39 PM
Chuck Harmon
The more power an engine generates, the faster it will wear out. Aircraft engines base their overhaul periods by estimates of engine load. The good thing is that even a Corvette driven modestly hard spends a very, very small fraction of its time under full throttle. The other strong point is that if highway driven, the engine is only turning about half as many revs as the C3 Vettes did. The several C3's that I owned also went well over 100,000 miles without problems, so I would expect my 2002 ZO6 to go way over 100K without problems. It has over 65,000 miles now without any issues or oil consumption problems. It is a very well built engine, the best one yet until they release the LS7.
Chuck
Old Jul 10, 2005 | 07:07 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
EyesOnly,
The life of a C5 Z06, while certainly potent at 405HP, is directly dependent on how it's cared for, driven, and maintained.
Oil changes using Mobil 1 synthetic oil combined with a high quality filter are paramount to the engines longevity. Oil life will vary with driving conditions. Excessive heat and high rpm's prematurely breakdown oils lubrication properties causing component wear and failure.
Proper lubrication of both engine and transmission will is only part of the puzzle, driving properly is another.
Bob
Old Jul 10, 2005 | 11:40 PM
SoulDad570's Avatar
SoulDad570
Originally Posted by EyesOnly
Greetings,
Thanks,
Jason
The LS6 is a very durable engine. GM uses its factory Corvette race program as a test bed for new Corvette technology. In that program, they are designing for endurance racing. A lot of this technology makes it back into the street Corvettes.
The LS6 is designed for racing, it's a waste (IMO) to "baby it". I suppose that driving it hard at the track for a weekend may take a little life from the engine. But I figure, what the heck? It's worth it. When it eventually wears out (whenever that is), I'll fix it.
There's no magic in how to make a car of any brand last a long time. Maintain it properly and "baby it", and it will last until your are sick of it.
Ciao,
Rick
Old Jul 11, 2005 | 09:34 AM
C5 CU's Avatar
C5 CU
I think should last past 100,000 miles ... may need to replace valve springs at around 60 to 75k, tune, fluids etc.
Old Jul 11, 2005 | 10:02 AM
Joe C's Avatar
Joe C
i think the current LS series of engines will run well into the 250K range (with reasonable care and maintenance)
Old Jul 11, 2005 | 11:49 AM
SoulDad570's Avatar
SoulDad570
Really? I hadn't heard that.. I checked my service manual and there is no mention of valve springs at all.
I have heard that if you put in a higher lift cam you may have valve spring problems. But that is aleviated by switching to racing valve springs.
Some also claim that frequent high-RPM driving causes valve spring fatigue. It would be nice to see something official about this.
On a related note, I read a quote by some NASCAR big-shot: When asked "What technology has advanced NASCAR performance the most?" His answer was "Valve Springs!".
Ciao,
Rick
Old Jul 11, 2005 | 01:53 PM
EyesOnly's Avatar
EyesOnly
Cruising
Well that's all good news to hear- obviously there aren't any Z06's out there with 200k on the clock yet, but it's good to know that these engines are generally capable of delivering long life. Now I just need to get the funds in order to get one...
Jason
Old Jul 11, 2005 | 02:30 PM
RiceEater Z06's Avatar
RiceEater Z06
thats completely unnecessary, other than checking fluids every so often, changing oil, filter etc, they are basically maintenance free for 100k. Much more so than my foreign cars which require regular service in 15-30k mile increments. Part of the reason I prefer working on/driving the vette more than the cayanne and saab i have.
Old Jul 11, 2005 | 02:32 PM
RiceEater Z06
thats completely unnecessary, other than checking fluids every so often, changing oil, filter etc, they are basically maintenance free for 100k. Much more so than my foreign car which requires regular service in 15-30k mile increments. Probably the easiest to maintain car ive ever had, part of the benefit of having a gm pushrod engine.
Old Jul 11, 2005 | 04:42 PM
Shylor's Avatar
Shylor
Most American engines can easily go past 100k miles if they were well cared for. But expect more problems than you would with less mileage.
Old Jul 12, 2005 | 07:03 AM
zo6vetteman2003's Avatar
zo6vetteman2003
Greetings,
Thanks,
Jason
As long as you service the engine at regular intervals there is no reason the engine won't go well over 200k. In fact, the C5's are all Gen III engines LS1/LS6, but the C5 ZO6 has not been around long enough to know what the actual average life is. The other Gen III family of engines are in the pickup trucks and SUV's. My buddy has almost 400k on his and never had a problem other than having to replace the starter once. I think GM engineered these motors to last, and the are very simple, stupid, straight froward. GM says the pistons are good for just over 500hp (LS1/LS6). When you start putting superchargers on them, then you are stressing the engines pretty good. I know alot of people that are riding around like that and they are still together though.
Old Jul 12, 2005 | 08:31 AM
C5 CU's Avatar
C5 CU
Rick
Right now there are several threads floating around of "stock" ZO6s with 60k+ miles that have had valve spring problems...not camed cars but stock...actually had a GM service manager suggest replacing springs at 75k in ZO6s to me also.
Old Jul 12, 2005 | 01:51 PM
JWB ZO6's Avatar
JWB ZO6
Chuck
Old Jul 12, 2005 | 02:50 PM
zo6vetteman2003
The problem with valvesprings is letting the car sit for long periods of time with the valvesprings compressed. This causes them to break even in the aftermarket.
Old Jul 12, 2005 | 07:42 PM
08msmZ06's Avatar
08msmZ06
I met someone recently who said he got 300K miles (mostly highway)
out of his C5 Coupe. He said he changed the oil religiously at 3K miles.
He sold the car for $10K, if you can believe it, when he bought his new
C6 Coupe.
To Engine Longevity
Old Jul 12, 2005 | 11:09 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
C6 Coupe.
Yes, I believe it. I read a article from GM stating that these cars should easily last 250k or more with proper maintance. Now us guys that run them very, very hard may see a little less, but time will tell.
Old Jul 13, 2005 | 09:57 PM
Dr Octane's Avatar
Dr Octane
I went to a popular DE course that specializes in Corvettes. I drove one of the ZO6's that had over 30K RACETRACK miles on it. The tranny was a a little sloppy, but the motor was as strong as ever. If you drive at 6500rpms alot of the time, a new set of valve springs might be in order at 75k mi.
Old Jul 13, 2005 | 11:34 PM
roSSco's Avatar
roSSco
Great news! I think I may never buy another car. Ever!
My '04 ZO6 is nearing 40k It's out of warranty, but it has never been to the dealer!
