Damn side air dam!!
Old Jul 18, 2005 | 02:06 PM
07blackcoupe's Avatar
07blackcoupe
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
Default Damn side air dam!!
I had to park in a lot in Newark, NJ (No choice!) last weekend and they had one rather large speed bump with the retractable spikes (REALLY SCARY!) and I tore away two of the three bolt holes for the side air dam in the bottom of the front fascia. I don't think there is a way to repair and I am not going to get a new fascia just for this. My question is how much will the side air dams, if removed, take away from the air induction. I don't really like the look of them anyway from the side and since one is damaged- I am thinking of removing both...
Any thoughts...
Thanks in advance
Old Jul 18, 2005 | 02:09 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I would have the lot pay for the damage. I don't think the sides ones help deflect any air into the engine, but are there for aerodynamics.
Old Jul 18, 2005 | 02:31 PM
TOPGUN9's Avatar
TOPGUN9
I can't remember off hand what the cost is for the side air dam pieces, but they're cheap. Probably your best bet would be Mid-America or Ecklers.
Old Jul 18, 2005 | 05:19 PM
VetteSiNz's Avatar
VetteSiNz
About $75 a set....center and left and right side air dam. Seen alot off Ebay.
The side air dams are very cheap (about $5 each). They do help with aerodynamics, but that is about it.
Old Jul 18, 2005 | 05:21 PM
NSTG8R's Avatar
NSTG8R
... i think he's saying he tore the bolt out of the front fascia.
Old Jul 18, 2005 | 05:26 PM
pewter99's Avatar
pewter99
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
use some washers when you remount it...
which side?? I have a spare one Left side I think...have to check...PM me and I will look if you damaged it beyond fixing but I know I used a couple washers on mine to cover the area of the torn hole...
Old Jul 18, 2005 | 05:45 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
You shouldn't have to replace the whole bumper cover for that. Just find a way to set some nutplates inside where the originals were.
Old Jul 19, 2005 | 08:21 AM
07blackcoupe
The side air dam is intact, the problem is that the two of the four original mounting holes in the fiberglass (sheet molded composite) fascia have been torn away as the air dam got stuck on the spiked speed bump. I took them both off for now and I am going to have to drill some holes in the access panel to remount. I was just interested in the effects of not having them at all. I drove today and really didn't notice any difference at all. I think that the car looks cleaner without the ugly plastic air dam hanging down on both sides. Maybe all I lost was 5-10 mph on my top speed. Oh well, I guess I will just have to settle for driving about 155-160 mph every day to work instead of the usual 170 mph for awhile!
Old Jul 19, 2005 | 08:26 AM
07blackcoupe
I didn't think of washers, that is a good idea also!
Old Jul 19, 2005 | 08:44 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
A friend of mine had the same problem and made a couple of sheet metal straps that he put in on top of the smc where it would be sandwiched between the sheet metal and the damns. He tapped the holes he'd put in them and screwed the damns back into place. Seems to work great.
Old Jul 19, 2005 | 05:27 PM
FKING1's Avatar
FKING1
Did the exact same thing. How does one get behind the SMC? There is no access from inside unless U take some inner panels off. Once the bolts are torn out the dinky clips they screw into cannot be repaired .
Fred
Old Jul 19, 2005 | 05:41 PM
cwhitpan's Avatar
cwhitpan
From: Pop on over and visit me at www.FixedRoofCoupe.com PA
I would have saved mine when I put on the ACI had I known ya'll needed em... Sorry! Sounds like a PITA... Good luck fixing it!
To Damn side air dam!!
