Jacking Details
Old Jul 18, 2005 | 11:57 PM
DoomDRV's Avatar
DoomDRV
Default Jacking Details
OK - My first mod is complete and works perfectly!
I installed my CAGs today. Everything went very well but I have one issue. My jack has a range of 5 1/4" to 15 " with a 2 1/4 ton capacity. Because of the 5 1/4 " start I have to drive up on home made ramps - no big deal. But to get the 2x4 wood block to protect the aluminum cross members I have to build higher ramps - again ok but...
Then I have my home made two puck jack stand holders. They work well but now I have to jack the front or back so high to get the jack stands to fit under the two pucks. I am worried as the jack is at maximum extension.
Do I get a bigger better jack or what. Advice appreciated!
Old Jul 19, 2005 | 01:27 AM
Cajun99's Avatar
Cajun99
Many of us use low profile aluminum jacks due to the car's ride height or being lowered. Much easier to get under the car.
For instance...when I change my oil I put a couple of short 2x4s in front on my grey Rhino ramps and drive right on up. I lay a small 2x4 on my jack's riser and there's enough clearance to get it under the rear cross member to raise the back of the car. I then put my jack stands out near the end of the cross member but NOT on the rear control arms or any moving part of the suspension. I do not put jack stands under my pucks to change the oil.
If I have to pull a wheel off I put the jack directly under the puck and raise that corner and slip a jack under the cross member. I don't use a 2x4 between the jack and the puck since I have a built in pad on the jacks riser.
Another benefit of these jacks is that it only takes about four pumps of the handle to get the car high enough to put stands under it.
ps...you already had CAGs...you installed a CAGs defeat
Old Jul 19, 2005 | 08:58 AM
yellow01's Avatar
yellow01
I don't personally use a 2x4 to protect the x-member.
I put a dish rag folded over 4 times or so to keep from marring the x-member, but it's plenty strong enough.
Just my input. I've lifted the car more times than I can count with no issues. [shrug]
Old Jul 19, 2005 | 09:47 AM
zonsolo's Avatar
zonsolo
Not sure if this is any good either, but I have a jack that has a small enough contact point on it that I can jack it directly on the spots where the pucks would go w/o touching anything but the space where the pucks would go.
So I just drive up on some boards in the front, and jack away.
Car's sitting on 4 jackstands right now, which brings up another interesting question...
Where's the best place to put jackstands?
Old Jul 19, 2005 | 10:39 AM
yellow01's Avatar
yellow01
I put them on the outermost are of the cross member, wherever there's cross-piece on the cross member (sorry for the phrasing).
The fronts go all the way on the outside at the corner, the rears I actually put them on the outer side that runs parallel to the car (it curves upward a bit).
This has always works well for me, and the car seems very stable. I've had it up for weeks like this with no issues.
I don't like putting on stands at the puck areas because it's sitting ON the stands. For the cross member, it's sitting IN the top of the stands (the tops of my stands are U shaped).
Old Jul 19, 2005 | 01:42 PM
DoomDRV's Avatar
DoomDRV
Yellow01
I think that makes a lot of sense particularily I like the idea of the member sitting into the jackstand. Do you use anything to protect the crossmembers from the u shape steel stand?
Old Jul 19, 2005 | 03:25 PM
yellow01's Avatar
yellow01
Sounds funny but I use some dish rags, folded over a few times (about an inch thick just folded).
This prevents marring, but the rag compresses enough and it is very stable. It also allows for a little settling if I don't get the cross-member piece centered exactly over the stand (allows for a little sliding/play when it settles without scraping the frame or stand).
Hope this helps,
Jon
Old Jul 19, 2005 | 04:14 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
I invested in a really versatile jack a few months back. Yes it is expensive ($400) but it is very low at 3.1" in the front and under 4" for the first 17", and has a long reach. I can get to the front crossmember without driving up on anything with this jack. It has a lifting height of 29" and has an optional ($20) flat rubber pad for the saddle. With the flat rubber saddle you don't need a 2x4 to protect the crossmember. You can also use single pucks instead of 2.
It is very easy to put the car up on stands (on the pucks) with this jack. All you have to do is raise the front at the crossmember, slide ramps under the front tires, then raise the rear at the crossmember high enough to slide jack stands under the rear pucks and then go back to the front and raise higher to get the jack stands under the front pucks and then slide out the ramps from under the front tires. This way you don't have the car up too high at either end at anytime during the process.
AC Hydraulics DK13HLQ
Old Jul 19, 2005 | 05:41 PM
DoomDRV's Avatar
DoomDRV
Thanks Everyone for the helpful replies
To Jacking Details
