I was wondering if any one could give me some insight on my AC vent suddenly stop working.....the air still blows cold but mainly blow out the defrost vent. There is some slight air coming out of the rest of the vents but not like normal. When I press the mode button to redirect air to floor, front, etc..... it doesn't make a different. Does anyone have/had this problem and know the fix?
Not absolutely positive on this but sounds like the mode button has ceased to operate correctly. It is not sending the message to the mechanicals to operate properly if all modes are failing. Cost for a fix? Sorry I don't have a clue. This could be a job for the professionals.
Another good possibility is that your battery has leaked acid onto the vacuum hoses for the AC vents. Once they have a hole in them I believe the venting defaults mainly to the defroster vent. It happened to me.
This is a really common problem. If you have ever had a battery leak this is probably the cause.
I have the same problem only my unit is stuck in the bi-level mode... I have an appointment with my friendly mechanic on Thursday... I did have a battery spill - Added too much water and it flowed out in the Arizona heat on a 300 mile trip. I remoed the battery and flushed the area... I have not been able to locate the vacuum hoses though... Does anyone have any idea where they are hiding???? Also, I read that the a/c would perform cooler if I reduced the freon charge to 1.11 pounds instead of 1.4... Is this true... Itis 120+ here right now and I need to cool things off in my beautiful Corvette!
Once I get my lug nut key ordered to get my wheels off, I will have figured out how to get to the vacuum lines, then I just need to figure out how to splice them.
i replaced my delco battery, and i had no acid leak at all.. im using another battery (forget the name... got it from NAPA), i really hope its not leaking!
could it be possible that im not getting air through the vents, and only through the defroster just because the freon is low? or do you think that i should replace the compressor too? (its ticking quite a bit...)
