I am looking to install HUD on my 01 z06. My question is the switch that is offered through Gene has the dimmer *** on it. I allready have the dimmer *** on my dash just below where the HUD switch goes. Is there another type of switch out there? What do I do about having 2 dimmer ****?
Denver
Denver
Your old dimmer **** will be replaced with the new switch/****
There is one dimmer **** for the output on the hud and a seperate control for the illumination of the dash lights. I have both ***** installed from the factory and they are both operational, You will need both.
But there are other switches without the ***. Like the other Z06 HUD switches. I am looking at one that the switch does not have the ***. it is accually the whole cluster but all I want out of it is the switch.
