Deploying
Old Jul 27, 2005 | 03:57 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Be careful out there...And thank you...
Old Jul 27, 2005 | 05:44 PM
Put some carpet squares under the tires, fill the tank and use something like Sta-Bil in the gas, hook up a battery tender, maybe put some mothballs in the engine bay (keeps rodents away) and some moisture packs in the interior. Stay safe over there.
Old Jul 27, 2005 | 05:53 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
[QUOTE=vettenovice]The battery tender advise, full tank, pump up PSI, and carpet pieces are right on. You don't need to do any more. Just want to say how much I respect you guys for going to bat for the entire country! Stay safe and be sure to post as soon as you get back!!!! : How about adding some stabil to the tank to keep the fuel fresh.
Old Jul 27, 2005 | 06:04 PM
mcburner's Avatar
mcburner
Same here....Stay safe, while kick'n some ****! And most of all..THANK YOU FOR YOUR SERVICE! You're car will be fine and waiting for your return...I'm sure. Thanks again.
Old Jul 27, 2005 | 06:09 PM
vettes4fun's Avatar
vettes4fun
Old Jul 27, 2005 | 06:55 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by MAJ Z06
Don't do this it will over extend your shocks. Just add some extra air, two months is no big deal. Put the battery on a trickle charger. I stored mine on deployments many times, a box of desiccant on the inside couldn't hurt either. A capfull of gas-stab before filling up also, and a good wash and wax.
Good luck and Godspeed.
Old Jul 28, 2005 | 05:56 PM
1vette98's Avatar
1vette98
God bless and thanks for your service. It's guys and gals like you who make it possible for us to sit around and BS about our cars here on the forum. Stay safe!
Old Jul 28, 2005 | 05:57 PM
sailohio's Avatar
sailohio
Originally Posted by StephenT
Keep Safe
Insted of disconnecting the battery you may want to hook it up to a battery tender. Fill it with gas and make sure the tires are filled with the proper PSI (maybe a few lb more) to avoid flat spots.
God bless you and be safe.
Old Jul 28, 2005 | 06:03 PM
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
Originally Posted by SLIK
Stay safe and God Bless!!
thanks
Old Jul 28, 2005 | 07:02 PM
JWB ZO6's Avatar
JWB ZO6
Battery tender and jack stands
Old Jul 28, 2005 | 07:21 PM
hibiscus805's Avatar
hibiscus805
God bless you and Thanks
Old Jul 28, 2005 | 07:31 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Yes, thank you for your service!
Be careful. God speed.
Old Jul 28, 2005 | 07:56 PM
  #33
Jim2003's Avatar
Jim2003
Thank you for serving for us. I am USAF during Viet Nham. Be safe.
Old Jul 28, 2005 | 08:00 PM
  #34
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Originally Posted by kasper-pA-
wouldn't hurt to put it on jack stands so your RF's don't get a flat spot...
GL and God bless!
I wouldn't go that far, I just over inflate them to 40 and park on pieces of carpet. Good luck and thank you for your service!
Old Jul 28, 2005 | 08:28 PM
  #35
ryanc440's Avatar
ryanc440
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Sounds about right. I've left mine during 2 deployments now, one for 3 months and one for 5 1/2 and this is what I did. Tires to 45-50 psi, fuel stabilizer in the tank, I took the battery out of the car and put pieces of plywood under the tires to help against flat spots. Came home, put the battery back in, let some air out of the tires and fired her up, worked like a charm. Take care, and watch yourself out there!
Old Jul 28, 2005 | 08:32 PM
  #36
Hot BluZ's Avatar
Hot BluZ
From: The problem with socialism is eventually the government runs out of other people's money
Keep Safe
Sitting for two months should cause any major problems, if it were significantly longer, say over 6 months, I'd recommend putting a fuel stablizer in the gas.
God bless for your service to our country, come home safe.
  #37
99 TorchRed's Avatar
99 TorchRed
Originally Posted by afone
I'm headed to Afcrapistan for 2 months... my question is what do I do with the Vette while I'm gone (Sorry, no you cant borrow it). Any precautions I need to take storing it in my garage other than maybe disconnecting the battery? Thanks!
Good luck during your two months in Afghanistan Stay safe!
My C5 is stored from October through late April. For remote storage, away from an immediate overview of the vehicle, I remove the battery and bring it to where I can charge it at least once a month. Other than wash and wax and a cover, nothing else is done. It fires right up in the Spring and so far I haven't even had to reprogram the fobs, which isn't difficult.
The biggest dilemma I've run into is avoiding storing the car in a mouse prone place, (commercial storage, barns, uninhabited garages). Vermin can make a shambles out of interiors and convertible tops with their gnawing and defecating. A dozen mouse traps strategically placed in and around the car and a few boxes of De-Con will see to it that if that occasionally mouse finds it's way to your stored Vette, it will not take up habitation in it.
To Deploying
Old Jul 28, 2005 | 08:33 PM
  #38
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Stay safe and come back soon. We salute you.
Old Jul 28, 2005 | 08:59 PM
  #39
jrose's Avatar
jrose
GOD BLESS YOU.
Old Jul 28, 2005 | 09:01 PM
  #40
lpabsolute's Avatar
lpabsolute
Originally Posted by P51tj
Good Luck and keep yer head down. Hurry home!
