I bought Delco pads for my ZO6 and according to my research it seems to be a relatively each switch; remove top and bottom bolts on the caliper and slip the pads into place.
Am I missing something or is there something I should be aware of? Any DYI site anyone can refer me to?
Certainly not adverse to having a mechanic do it but wouldn't mind doing it myself.
Should be that easy. I would suggest you change the rotors too while you're at it (or have them machined. They are cheap enough to just replace from NAPA.) It's always best to start with two smooth surfaces.
You may require a large "C" clamp to push the piston back in replacing the pads.
Don't forget to undo the cap to the brake master cylinder so that the fluid has somewhere to expand prior to doing this! Also worth putting some rag around the neck of the cap to ensure that any fluid doesn't escape.
It is very important that you remove the caliper pins and clean and lube them with silicone grease, otherwise the calipers will not "float" and release properly.
[QUOTE=You may require a large "C" clamp to push the piston back in replacing the pads.[/QUOTE]
Please don't do this. You will force old fluid and debris through a directional check valve "if present". They are partially right, but before you compress the caliper piston back into position, get a small hose and attach it to the bleeder on the caliper. Open the bleeder valve first and then compress the caliper piston back into position. What will happen is the old, dirty, burnt up fluid that is in your caliper will exit out the bleeder valve into the bottle or can you have supplied. Then don't forget to tighten the bleeder back up. "Warning" Leave other calipers on rotors so you do not force the caliper pistons out of the there calipers. Good luck.
Thanks, in advance, for any input.
John
Just be careful not to use ceramic pads with drilled or slotted rotors. I loved the ceramic pads right up until the time they cracked and literally crumbled off of the caliper.
I did not do my due diligence before getting them to find out that they dont play nice with drilled rotors (afterwards, i have also found out that they sometimes dont play nice with slotted rotors either)
If you have ever changed disc pads in the past it's the same process and just as easy. Most of your time will be jacking the car. Know is the perfect time to change out the enter break fliud aftert you have replaced all your required pads. I put cermanic's on all four wheels with not problems and replace my nasty black fliud. Sure do love the clean wheels I have every day from the Low dusting from the ceramic pads. Never noticed the lose of breaking mentioned by fellow Z drivers, but I'm not driving in autocross events. I do push my Z hard at times but I still hvae plenty of break pedal for my driving style
