Optima Battery Question
Old Jul 29, 2005 | 01:58 PM
HOTSOSS's Avatar
HOTSOSS
Default Optima Battery Question
For those that have installed the Optima Red Top battery in their C5's, did you use the plastic holder on the bottom of the battery or just install the battery with the factory hold down clamp. Mine seems to want to come loose when using just the hold down clamp.
Old Jul 29, 2005 | 01:59 PM
injuner's Avatar
injuner
I installed mine with the factory hold down clamp and it has been working fine so far.
Old Jul 29, 2005 | 02:08 PM
matt24's Avatar
matt24
First time i installed it it worked fine now i cant get it to hold the battery down. I just left it bc theres not really any where for it to go.
Old Jul 29, 2005 | 02:22 PM
HOTSOSS's Avatar
HOTSOSS
Well, it can move around and bang into stuff and damage the battery. It is not good for the battery or the wires anyway.
Old Jul 29, 2005 | 02:23 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
What size battery do you have?
Old Jul 29, 2005 | 02:38 PM
HOTSOSS's Avatar
HOTSOSS
part number 75/35-925 which is about the same size as the original battery (maybe slightly smaller outside dimention).
Old Jul 29, 2005 | 03:01 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I have the 75-35 and it fits perfectly with the factory hold-down clamp. It is snug and will not move at all in any direction. Make sure that you are positioning the battery correctly in it's place and you should have no problems. This is the second Red Top I have installed, one in my first C5, a '98 Vert and now in my current car. Fits like it was made for it.
Old Jul 29, 2005 | 03:08 PM
vetdude's Avatar
vetdude
You have to wiggle it into place but once the bottom edge fits under the lip on the battery tray, you're good to go.
Yoggi's Avatar
Yoggi
Me too
Old Jul 29, 2005 | 03:28 PM
HOTSOSS's Avatar
HOTSOSS
While I was waiting on your replys, I installed the red tray with the hold down clamp that was supplied with my first battery (a little smaller with a protrusion that fits in the slot of the tray). It holds the tray down fine but the battery can move up and down in the tray and I don't think this is good either. So I will use the factory clamp without any Optima trays and secure the bottom of the battey with the factory clamp. Since it has come loose several times, I will work on the position to see if I can get more grip.
Just tried and it won't hold. If I use the red tray that comes with the Optima, then at least it won't slide around. Just hope I never turn over cause it will come out that way. Thanks.
Old Jul 29, 2005 | 05:33 PM
I used the factory hold down clamp too. So far, after almost four years, no problems.
Old Jul 29, 2005 | 05:37 PM
LoneStarFRC's Avatar
LoneStarFRC
I've got the 34/78 series and I 'm using the Optima clamp. It has the semi-circular shape to fit up against the battery. Holds tight.
Old Jul 29, 2005 | 05:41 PM
HOTSOSS's Avatar
HOTSOSS
Thanks to all that replied, I have figured out how to secure the battery. The back of the battery wasn"t in the "box" properly, kinda on the lip and allowed the battery to slide back and out of the clamp. Once I realized this, I installed the back of the battery first, then used the clamp supplied by Optima to hold the front of the battery. It kinda forces the battery into the box as the Optima is just slightly wider than the box. Anyway seems to be a real tight fit. Thanks to everyone that responded.
Old Jul 29, 2005 | 05:55 PM
xlr8shn's Avatar
xlr8shn
There are at least two diff form factors of red top. The one I have works perfectly w/stock hold down. Do a search and you'll find the two form factors...
Old Jul 29, 2005 | 07:41 PM
stevzc5's Avatar
stevzc5
Me too. It fits like a glove.
Old Jul 29, 2005 | 08:02 PM
C5naples's Avatar
C5naples
Same here!
Old Jul 29, 2005 | 08:43 PM
2fast4sanity's Avatar
2fast4sanity
But I think i have somehow managed to almost strip the threads in the negative side terminal. Doesn't want to tighten all the way. It starts to get tight and then gets loose again.
To Optima Battery Question
Old Jul 29, 2005 | 09:24 PM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Yeah, mine just wouldn't stay so I used the plastic holder on the bottom.
Old Jul 29, 2005 | 09:44 PM
LB04CE's Avatar
LB04CE
factory hold down
Old Jul 29, 2005 | 09:45 PM
ROJ#79's Avatar
ROJ#79
