Pull Key Wait 10 Seconds
Old Jul 29, 2005 | 10:32 PM
Dave1998's Avatar
Dave1998
Default Pull Key Wait 10 Seconds
Started car today, warmed it up, put in reverse and died. After 3 times saw the above message. I put the CLB in my 98 a few weeks ago but thiis is the first message.
So do folks thing that this is CLB related or key resistor related ? Past posts go both ways. I am confused. Car has few miles so key is not worn out.
Old Jul 30, 2005 | 12:07 AM
Armadillo's Avatar
Armadillo
Had the same thing happen to me one time. I think it is key related, but some folks are convinced it's a column lock issue as you noted.
Old Jul 30, 2005 | 12:17 AM
GrayC5's Avatar
GrayC5
Check out the following thread that went around recently in C5 Tech:
Pull Key for 10 Seconds...Quick Q???
Good luck.
Old Jul 30, 2005 | 09:07 AM
Dave1998's Avatar
Dave1998
Its unfortunate that we in this forum cant figure this 1 out. Some day the answer hopefully will jump out at us !
Old Jul 30, 2005 | 10:59 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
I had the recall done months ago, mine is a 98 A4, had the plate removed and K-harness in stalled by the dealer. A week or so ago i got the same messege, and the fuel cut off....It had to be towed to the dealer and what they found was a bad relay in the K-harness and it was replaced. Don't think for a minute that you will never get stung just because the recall has been performed. However from what I understand it can be many things that can cause this issue. Good luck
BTW...The dealer had my car for only one day and it was back to me and I didnt pay a penny for the tow or anything Bob McDormans in Ohio
Old Jul 30, 2005 | 11:06 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Originally Posted by Armadillo
Had the same thing happen to me one time. I think it is key related.
Had that happen to me once also... at the drag strip. Thank god it went away and never came back.
VR
Old Jul 30, 2005 | 11:11 AM
r98vette's Avatar
r98vette
Default wait 10 sec
it happend once about 2 years ago in my 98 never had it again i think it might be tied to the theft system because it does shut the fuel off
Old Jul 30, 2005 | 11:12 AM
neesie's Avatar
neesie
I have a 2000, and had the recall done. I have had the "pull key wait 10 seconds" message 4 times since the recall was done. Before the recall, I had only gotten the message once. I am taking it back to the dealer on Monday. I dont have the CLB, and of course the dealer didnt recommend it or even know about it. I dont know what I will do if they dont fix the problem. It has always started right away after the message though. But I have heard of people being stranded where it would never start.
Old Jul 30, 2005 | 12:11 PM
Dave1998's Avatar
Dave1998
I have a 98 MN6. Never had recall done as I dont want the fuel shutting off. I put in the CLB. It appears the fuel did shut off anyways.
Well, I just hope the message dont come back !
Thanks for comments
Dave
Old Jul 30, 2005 | 01:33 PM
JYC5's Avatar
JYC5
Happened to me last Sunday. Stopped to get gas, started the car and the steering wheel was locked with the same message. "Pull key wait 10 sec". I did that then it said "service column lock". Monkeyed with it for 15 min to no avail. Called a tow truck and towed to the dealer. I had received a few mo's back a re-call for this, so figured it was covered....NOT. Dealer said it was the column lock module which is not a part of the re-call. Spent 2 hrs on the phone with GM. First person said they'd cover it, then they called the dealer then changed their mind. In all it cost $379 bones to replace module. Then had to take it back to my tuner to reprogram the PCM back to my spec's. OH, GM said they'd send me $400 bucks off for my hassle on a new or used GM car. Whoopee
Old Jul 30, 2005 | 05:11 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
This also happened to me 2 days after I bought the car, it's an 01 w/ 23K. I thought it was going to be covered, but the dealer said my lock actuator failed and won't unlock, and I had to shell up $500 for the part, labor, and towing(they even got me there!). Fortunately, the dealer I bought it from is covering it, or at least half, I'm still waiting it. It really sucked, but I was fortunate this didn't happen on the trip back to TN and got stuck in the smoky mountains or anything (boy...you got a PUUURTY mouth!)
Old Jul 30, 2005 | 10:07 PM
neesie's Avatar
neesie
My fuel shut off even before the recall. I am reading other replies to this, now I am worried about taking it to the dealer on monday. Who knows what they will charge me??????
To Pull Key Wait 10 Seconds
