[Z06] auto conversion
Old Jul 31, 2005 | 12:05 PM
vrybad's Avatar
vrybad
Default auto conversion
Just wondering if anyone has done an auto conversion on a z06.
I know, it kills the whole point of having the z06, but for drag racing, it would sure help consistency, and also lessen the stress on driveline parts.(most important!)
I'm looking for a z06, and like the potential of the auto for a street driven, high hp car.
Not sure I'd do it, just curious.
Just an idea, if anyone can point me in the right direction to get some questions answered, I'd appreciate it.
Thanks,
Brian
Old Jul 31, 2005 | 04:21 PM
J Z06's Avatar
J Z06
There are a few hardtops running around with automatic's. Not too sure what is involved to convert it...but it's true. Automatics hit the tires a LOT less and there isn't that sudden shock to the driveline like a stick launch.
I'm sure a few will chime in. You could cross link this in the drag racing section too.
Jay
Old Jul 31, 2005 | 08:24 PM
vrybad's Avatar
vrybad
Thanks, Jay.
Yea, I considered the hardtop route, but it would be kinda neat to do the z06 conversion.
I'd really like a z06 to start with.
I'll poke around in the drag section again, maybe it's been covered and I missed it.
Old Jul 31, 2005 | 10:55 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Originally Posted by vrybad
Thanks, Jay.
Iv'e been wondering myself. An automatice would sure be more consistant.
Old Jul 31, 2005 | 11:45 PM
shurite44's Avatar
shurite44
Hi, I researched this issue a few months ago. The transmission I would go with I listed below. From what I can remember you could have this transmission installed with a high stall torque converter and set up ready to go for around 5k.
4L65E TRANSMISSIONS Price 1975.00
24221888 - 4L65-E Four speed rear-wheel-drive, electronically controlled, automatic overdrive transmission with a torque converter clutch.
GM Hydramatic has baked even more technology enhancements into the automatic transmission line up with the new 4L65E. This transmission, the latest creation from GM Hydramatic Motorsports, is a four speed, offering all the latest heavy duty components to stand up to the power of the LS6-405 HP Corvette engines. Upgrades like induction hardened turbine input shafts, larger intermediate servo, an additional three-four clutch plate. All go toward accommodating higher engine power output. The 4L65E offers optimized performance, fuel economy and increase durability. This sate-of-the-art transmission features the latest heavy duty components and high tech-electronic controls. The advanced electronics controlling the LS6 engine also manages the 4L65E shift points, providing unparalleled performance and durability, P/N 24221888 also includes the torque converter. (No core charge required on this transmission)
4L65E gear ratios: 1st 3.059, 2nd 1.625, 3rd 1.000, 4th .0696, Reverse 2.294.
Engine Range: 6.0L (M32)
Maximum Shift Speeds: 1-2 5600 rpm (M32), 2-3 5600 rpm (M32), 3-4 5600 rpm (M32)
Maximum Engine Torque: 380 lb-ft (M32)
Maximum Gearbox Torque: 670 lb-ft (M32)
Converter Size: 300mm (M32) (reference), Diameter of torque converter turbine.
Fluid Capacity (Approximate): 10.8L (11.4 qt) (with 300 mm converter)
Case Material: Die Cast Aluminum
Assembly Sites: Toledo, OH; Romulus, MI; Ramos, Mexico
Technical Notes: Use with transmission controller P/N 12497316. (No core charge required on this transmission)
Old Aug 1, 2005 | 05:05 AM
vrybad's Avatar
vrybad
Thanks much for the info.
The only question I have is in regard to the torque specs for the trans you listed.
Looks kind of low for a true drag application, especially with a big increase in hp.
I guess the trans could be upgraded like the 4l60 to take the high hp app's.
Thanks again.
I probably won't do the conversion, just wanted some food for thought.
Old Aug 1, 2005 | 08:15 AM
shurite44's Avatar
shurite44
Thanks again.
Yea you are correct if you did much to the engine the tranny would have to be beefed up. I was in the same boat, just sort of researching the possibility of doing this. I love the FRC body style but I am a bracket drag racing enthusiast. I think I am leaning towards the 2006 C6 A6 now.
To auto conversion
