Adhessive for SS Inserts
Old Aug 1, 2005 | 10:24 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Default Adhessive for SS Inserts
I got the SS inserts for both the front and rear and was planning on putting them on today. What I was wondering is what adhesive you guys would recommend. I know I should clean the area with denatured alcohol and the letters already come with some sticky tape on them. Call me paranoid but I don't want these things flying off, so what did you guys use, in addition to the stick stuff already on them to make sure they stick for good?
Old Aug 1, 2005 | 10:34 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
If you clean well, you'll have no problems. Main thing is to have a superclean surface with no wax................
Old Aug 1, 2005 | 10:47 AM
LarryW's Avatar
LarryW
Use the stuff that came in a small brown bottle (or packet, can't remember which version I got with mine); it is some sort of adhesive promoter and should be applied using a Q-Tip AFTER you have thoroughly cleaned the area using alcohol as mentioned
Old Aug 1, 2005 | 11:34 AM
Pipes's Avatar
Pipes
Do Not Use Superglue!
I used superglue this weekend for rear Corvette lettering, it was a mistake. It can blister your paint if you're not extremely careful.
On the other hand, I'm guessing that the letters will stay put.
Old Aug 1, 2005 | 11:44 AM
AdamC5's Avatar
AdamC5
Clean the surface well with alcohol + use the adhesive promoter
Should be perfectly fine. That 3M stuff is insane
Old Aug 1, 2005 | 12:48 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
When I put mine on 2-years ago the sticky tape started to come off as I was trying to remove the backing on the "O". I ended up removing all the adhesive and installing the rest of them with 3M Super Adhesive. The "C" was the only one I installed with the tape, and I lost it about 6-months ago. Got a new one and installed it with 3M Super Adhesive.
Old Aug 1, 2005 | 01:30 PM
berryj's Avatar
berryj
Where did u buy the extra "C" from?
Old Aug 1, 2005 | 01:46 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
I looked around and even called the manufacturer and could not just buy one letter. Since I didn't want to drive around in an "ORVETTE" I bought another set from Ecklers. If I ever lose another letter, hopefully not "C", I will have a replacement.
Old Aug 1, 2005 | 02:00 PM
HIVLCTY's Avatar
HIVLCTY
I put on my SS inserts about a month ago, and the thing that I learned is to let the primer, that comes with the letters, dry first. I tried to put the letters on when the primer was still wet and now my R is not sticking too well.
Old Aug 1, 2005 | 05:19 PM
csexton's Avatar
csexton
No problems here so far.
Old Aug 1, 2005 | 05:37 PM
GMvert's Avatar
GMvert
I had a problem with the "-" in one of the E's in front. It fell off with in a few months after installation. Called SS and they said they would send out another "-". Several months latter it never arrived so I ordered a new front end set. Now at least I have an extra set.
Old Aug 1, 2005 | 06:09 PM
TOOGECKO's Avatar
TOOGECKO
Cleaned mine well, used the supplied adhesive promoter and have had no problems in 1-1/2 yrs. Just be careful when washing/waxing to not snag on letters...
Old Aug 1, 2005 | 06:41 PM
Vette_Fan's Avatar
Vette_Fan
After reading all this, I'd say get the 3M super adhesive stuff. Better to be safe than sorry.. I bought mine from West coast corvette, haven't installed it yet. But I'd hate to loose one of them letters. I paid $70 for the rear letters set. I can't imagine paying $140 (for 2 sets), if I ever needed another letter. So, I'll get the 3M stuff, whenever I'm ready to install it... Its up to you what you wanna do..
Old Aug 1, 2005 | 06:55 PM
MattB's Avatar
MattB
Just check every time you wash your Vette. My ‘R’ started coming off a week after install. I washed and used denatured alcohol, and I can’t imagine that the adhesive promoter was not dry when I put it on. It was +100 for the four days following and I did not wash it until the 4th day. My ‘E’s are not looking great either.
I remounted the ‘R’ with the 3m heavy duty spray adhesive, which is pretty messy. So far so good, just a mess to deal with. I do not think it would be wise to start with the 3m spray, just use it if one of the letters fail.
Over all I like it , and I’ll just have to check the lettering every time I wash for a while.
Old Aug 1, 2005 | 07:17 PM
berryj's Avatar
berryj
Is this 3M super adhesive the same thing as their double sided tape or the spray stuff that tends to be messy? Just wondering, because my SS kit from SS inserts didn't come w/ any alcohol prep and I blindly put my letters on without it! I'm thinking I may need to go back and do it right :o
Old Aug 1, 2005 | 08:23 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
The "R" on my front was loose. Saved my receipt and e-mailed WCC. Got my new "R" on Saturday. No charge.
Old Aug 1, 2005 | 09:49 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Six months and no problems yet.
To Adhessive for SS Inserts
Old Aug 1, 2005 | 10:14 PM
jrose7004's Avatar
jrose7004
Mine have been on for 18 months!
Old Aug 2, 2005 | 08:09 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Follow the directions, make sure area is squeaky clean and take your time. No prob.
Old Aug 2, 2005 | 08:53 AM
DeeGee's Avatar
DeeGee
Mine are stuck tight
